When I turn on the projector, it works well, but after a few minutes, the colors are changing and flashing, until finally after about 5 minutes it shut down
  • 2,509 Answers
Check air flow and filters are clear, it sounds like it's overheating.
Posted on Nov 24, 2014
SOURCE: projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
Marrie
  • 563 Answers
SOURCE: Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Posted on Mar 25, 2008
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
Mitsubishi EX200U projector, repaced bulb, projector turns on for 10-20 seconds flashes different colors and makes a ticking sound and shuts off. Lamp light turns on.
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 07, 2014 | Mitsubishi EX200U Projector
Cleaning problem
1,the color starts to go out, it become the white and black ,
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 16, 2014 | ViewSonic PJD5133
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Jan 17, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
NEC LT265 Multimedia Projector will turn on, but does not fire up
the bulb needs to be resetted after fixed or the other problem is that the bulb is not fixed.or the ballast is faulty. check out all the options 1 by 1 in the given link how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | NEC LT265 Multimedia Projector
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Projector
The sound came from the switching power supply and the lamp ballast circuitary. You need to replace the color wheel sensor, I can fix it.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Projectors
The color wheel sensor is bad.
Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Nov 19, 2006 | Mitsubishi HC900U Multimedia Projector
jasbo
jasbo
