Question about Samsung Televison & Video
I was told I needed a new ASSY-SMD Digital I beleive this a board. My tv is a Samsung hlr5667wa/xaa can you tell me the partnumber for this board I see different numbers but dont no which one goes to
I was told I needed a new ASSY-SMD Digital I beleive this a board. My tv is a Samsung hlr5667wa/xaa can you tell me the partnumber for this board I see different numbers but dont no which one goes to this board. My tv goes off and on and then completely off.
  • 3,506 Answers
With the make aqnd model any tv repair shop should be able to help you.
Posted on Nov 24, 2014
ladywinn
  • 5138 Answers
SOURCE: Samsung HCP4363WX/XAA
Was wondering if you got set fixed yet? STK-392-180s are the ics I use when repairing convergence.Replace both chips.
Posted on Mar 31, 2008
tvtek
  • 1284 Answers
SOURCE: can you look up the digital board model part i need too?
BP94-02084A is the digital board part number for your TV
Posted on Aug 04, 2008
  • 179 Answers
SOURCE: how do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
Posted on Dec 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: I purchased the convergence chips for Samsung
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Posted on Dec 24, 2009
Testimonial: "Interesting thought. I can return the chips and have a new board in 3 days. The hardest thing is to get to 1 front screw-rest is easy. Thank you."
SOURCE: blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Posted on Apr 22, 2010
My samsung tv LNT4669FX/XAA screen is blank but the tv and backlight work. how do i fix the tv?
It sounds like the screen may have failed, that means a new TV will be needed.
Feb 24, 2017 | Samsung Televison & Video
Intermittent black lines samsung hlp5067w
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
Nov 18, 2013 | Televison & Video
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung LNR408DX/XAA Won't power up. Sound works but as far as the screen, no input/source works. After it died I noticed that the screen was very hot especially the upper Left side. In the dark, the...
It sounds like this is a problem with the inverter boards on the LCD panel. Unfortunately the inverter boards are usually only available with the whole LCD panel and the only way to fix it is by replacing the whole LCD panel. This is the most expensive part of the TV (about $1000) and you will need to take the whole TV apart in order to replace the panel. A new TV of similar make and model will usually be about the same price as the repair.
Nov 09, 2009 | Samsung LN-R408D 40 in. LCD HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Can you look up the digital board model part i need too?
Jul 25, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture only sound
this error is mostly caused by a defective line output transformer T511 (partnumber 1-453-308-31) and line output transistor Q533 (partnumber 9-948-014-40).
Also resistor R518 (2k7, SMD) could have been damaged.
All components are located on the main (A-) board.
Jan 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture issue
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
