Question about Toshiba Satellite Computers & Internet
How do I stop my lapto from turning off to screen saver
I have tried to change the screen saver and reset time off screen stays on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Goto control panel, personalization, screen savers settings, turn off screen saver , click ok
Posted on Nov 24, 2014
2 Suggested Answers
  • 825 Answers
SOURCE: i tried to chang the screen saver but it keeps going back to the bubble screen saver
I think you are using the Windows7 Starter edition. This version does not allows you to customize settings.
Please clarify if you have any doubt.
Posted on Feb 06, 2012
My screen is black.
A component may have failed. Perhaps requires service.
Make sure the screen hasn't been accidentally dimmed.
Feb 08, 2016 | Sewing Machines
Asus advertising after short time idling, how to stop it
it is not a video ..but it is probably a screen saver with some kinda advertising on i t...Assuming you have windows Xp on the notebook ...I suggest to click right on the desktop ... select properties(on bottom ) ..and in the window that will open ...select screen saver..and under this feature ..browse and select none ...Click apply ..to make the changes..and ok ..This way you will eliminate the screen saver for good..and will stay always on ..
Also from that feature with the screen saver it is possible to change the power management feature..somewhere in the same window..on the bottom ..If the display shuts down after a while ..or the hard disk ..and you need it always on ..even when it is idle ..than click the power management link ..and in there select never for all features..and apply ..and ok ..
Thats all ...
For windows 7 ..the procedure is the same but click right on desktop ...select personalize and in there look at the bottom there are a few categories and one of them is the screensaver...select it ..and same way ..remove the screen saver by selecting <<none>> and applying .
Nov 22, 2011 | ASUS Eee 4G Notebook
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
Screen saver wont stay on after setting it when i turn computer off and then back on
screen savers only come on after comp is inactive for what ever the time period you set this is usually 10 min.
hope this helps.
Apr 26, 2010 | Acer Computers & Internet
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
Monitor will not stay on. tried menu reset did not work. screen will not stay on long enough
check the wether your screan saver is turn on
or check the monitor sleep time is on for 20 minute
ok bye..............................
Nov 08, 2009 | Computers & Internet
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Screen saver problems boot problems
ok the disk check can be turned off in the bios setup
when you turn it it it says something to the effect like
"Press Del to enter setup"
what ever key it ask you to press press it..
in the setup change the first bioot device to HD0 or hard drive
Change the Floppy seek to off..
as per the screen saver,,
Try changing the screen saver to another one
If that fails turn the screen saver off
If that fails try a system restore to a date that this problem was not occuring..
IF THAT AS WELL FAILS THEN IT COULD BE HARDWARE RELATED
eighter memory or processor..
Jan 15, 2008 | Computers & Internet
4700 photos no longer scrolling on screen saver
you may want to change the time after which the IPAQ turns itself off. If this time is too short, then Dockware may not be activated.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
Computers & Internet Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
