Question about Kitchen Ranges
<!-- from fixya rte -->How do I stop my stove from beeping F1 - Kitchen Ranges
  • 3,506 Answers
Try unplugging it for 10 or more seconds ands then plugging it bqck in again
Posted on Nov 24, 2014
the dr
  • 447 Answers
SOURCE: magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Posted on Oct 04, 2007
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 126 Answers
SOURCE: amana stove with F1 beeping code.
Amana is now owned by Whirlpool. The customer service number is 800-253-1301. If you have reciepts (Proof ) of service calls you may be able to negotiate some form of concession. Good luck it can be a frustrating process.
Posted on Dec 29, 2008
huuum
  • 750 Answers
SOURCE: stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Jan 31, 2009
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
Why does my hotpoint, electric ignition gas stove beep -F1-
You are having connection issues, or a failing keypad. Disconnect the power. Pull down the control panel and disconnect the thin, flat ribbon connector that goes from the keypad to the control board, then re-connect the power and see if the F1 returns without the keypad attached. If it returns, get the computer board rebuilt at Corecentric Solutions. If the F1 doesn't return, buy a new keypad... Help Me Find My Model Number RepairClinic com
Jul 31, 2016 | Hotpoint Kitchen Ranges
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
My F1 Code keep beeping.
I think you must post full information about your stove
Dec 06, 2013 | GE Kitchen Ranges
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Wolf built-in Wall Oven 762. Convection Fans stop turning intermitantly Oven shut down with F1 warning Later restarted ? meaning of F1 warning
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
http://www.applianceaid.com/fault_codes.html
click the link
Dec 06, 2008 | Kitchen Ranges
Stove beeping
FRIGIDAIRE
Code
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
