Question about Whirlpool Washing Machines
<!-- from fixya rte -->My whirlpool washer does not rinse - Whirlpool Washing Machines
  • 2,509 Answers
Is it emptying the water properly? Check pump is operating and filter is clear.
Posted on Nov 24, 2014
4 Suggested Answers
  • 19 Answers
SOURCE: whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Posted on Feb 01, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool washer. stops at the rinse cycle. how
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, this is a common symptom of a lid switch malfunction. The following link explains how to access and tighten or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 25, 2009
  • 1531 Answers
SOURCE: my whirlpool washer stop working before it rinses
you need to check the lid switch,and the actuator arm
Posted on Mar 12, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My whirlpool washer stop working before it rinses
Mar 12, 2010 | Kenmore 22942 Top Load Washer
Whirlpool washer new..,. washes cold wash cold rinse.. hot wash cold rinse.. but on warm wash is cold wash cold rinse I can send wasdher back just got it t0 day or is there something I can do?
Be sure the hot water valve is all the way opened first. Both faucets must have equal pressure for washer to work properly. They all rinse with cold water, this is normal.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ingis washer will not engage rinse cycle
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin and rinse problem with whirlpool washer
check your drain hose and pump maybe something clogging it
Nov 15, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer goes through extra rinse every time
it showes that the machine has a second rinse switch on the console set it to no second rinse
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
