Location of thermal sensor on wd65738
Find location on engine
    Scholar:
  • 195 Answers
If this is one of those mits sets that come up with the "airflow message" and then shuts down--the thermal sensor is behind the lamp housing--mounted on the back side of it, near the top.... but it is NOT likely bad-only the connector goes bad. Pull the engine, remove this little white sensor and HARD WIRE it to the connector---IOW_-cut OFF that connector on both sides and SOLDER the leads to the sensor. This WILL take care of the airflow issue with this set.
Posted on Nov 26, 2014
Testimonial: "I pulled out the engine and there was no thermal sensor at all I've never ran into a DLP that does not have a thermal sensor or that has been modified this TV has nothing at all ,that's why I asked this question ,now is it suppose to have a thermal sensor if it does can you send me a picture of where it goes at and where it connects to please thank you"
Where is the engine no located
to many engines out there to give a good answer
try this for now
nonspecific downloadble document on engine number locations
[DOC]Engine Number Location Chart No 2. - RVCS rvcs-prodweb.dot.gov.au/vehicle%20identification%20and%20engine%20number%2...
VSS VEHICLE IDENTIFICATION AND ENGINE NUMBER LOCATION CHART SYSTEM. GRIDLOCATION CHARTS ... Chassis Number Location Chart No 9.
May 19, 2016 | Cars & Trucks
Where is the camshaft position sensor located in a
The camshaft position sensor is located on top of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
The camshaft position sensor is either located near the top of the engine, passenger-s side, or on the right side of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the camshaft pulley.
This sensor is located at the front of the engine near the camshaft gear this is what I got 6 different locations manual covers 99-05
Oct 10, 2014 | Cars & Trucks
Where is the cam shaft sensor located on my g6?
THE 2.4L ENGINE CMP SENSOR LOCATED REAR OF THE ENGINE CYLINDER HEAD. FOR THE 3.5L ENGINE CMP SENSOR LOCATED BEHIND TOP OF TIMING COVER IN FRONT OF THE INTAKE MANIFOLD. FOR THE 3.6L ENGINE HAS 4 CMP SENSORS LOCATED TWO ON EACH CYLINDER HEAD. FOR THE 3.9L ENGINE CMP SENSOR LOCATED IS LOCATED ON THE FRONT OF THE ENGINE ABOVE THE CRANKSHAFT PULLEY BELOW THE POWER STEERING PUMP PULLEY.
Aug 12, 2011 | 2006 Pontiac G6
Locate crank shaft sensor on 1998 jeep grand cherokee
4.7L ENGINE CRANKSHAFT SENSOR LOCATED ON THE ENGINE BLOCK ABOVE THE STARTER. ON THE 4.0L ENGINE CRANKSHAFT SENSOR LOCATED TRANSMISSION BELL HOUSING AT THE LEFT REAR OF THE ENGINE. THE 5.2L 5.9L CRANKSHAFT SENSOR LOCATED ON THE ENGINE BLOCK BEHIND THE RIGHT CYLINDER HEAD.
Nov 26, 2010 | 1998 Jeep Grand Cherokee
Where is the temperature sensor located on the engine ?
This car comes with two diffrent engines, you didnt list the engine size so i will give you diagrams with the location for both engines, hope this is helpful, the 3.8 engine the sensor is located on the top right of the intake manifold, and the other engine is located on top left rear of engine below throttle body, heres are the diagrams and i labeled them good luck,johnjohn2_7.gifjohnjohn2_8.gif
Nov 05, 2010 | 2004 Pontiac Grand Prix
Where is the knock sensor located on my 92 Jeep Cherokee 4.0L straight 6 4WD?
I don't see the knock sensor on the 4.0L engine. --- COMPONENT LOCATIONS Fig. 1: Electronic engine control component locations - 2.5L engine shown 91074g07.gif
Fig. 2: Overhead view of the (A) automatic idle speed motor, (B) MAP sensor, (C) crankshaft position sensor wiring harness, (D) air temperature sensor, and (E) throttle position sensor - 1992 Cherokee with the 4.0L engine shown 91074p15.jpg
Fig. 3: Electronic engine control component locations - 4.0L engine shown 91074g08.gif
Fig. 4: Electronic engine control component locations - 5.2L and 5.9L engines (Part 1 of 2) 91074g05.gif
Fig. 5: Electronic engine control component locations - 5.2L and 5.9L engines (Part 2 of 2) 91074g06.gif
Sep 30, 2010 | 1992 Jeep Cherokee Briarwood
Where is the oil presure sending unit in an 1996 pontiac grand am manual 2.4 liters 4 cylynders.
Here's a copy of component locations for various engine sizes for the 1996 Pontiac Grand Am that I had on my online resource.prev.gif next.gif COMPONENT LOCATIONS The component locations shown are typical, and may vary slightly from one model year to another, because of variances in manufacturing and assembly. Fig. 2: 2.0L Engine Component Locations 91064gtt.gif
Fig. 3: 2.3L Engine Component Locations — 1988–90 91064gtu.gif
Fig. 4: 2.3L Engine Component Locations — 1991–93 91064gqa.gif
Fig. 5: 2.3L Engine Component Locations — 1994–95 91064gqb.gif
Fig. 6: 2.5L Engine Component Locations 91064gtw.gif
Fig. 7: 3.1L Engine Component Locations 91064gty.gif
Fig. 8: 3.3L Engine Component Locations 91064gtz.gif
Aug 29, 2010 | 1996 Pontiac Grand Am
Where is the oil sending unit on a 1996 ford taurus 3.0 liter engine located? glenn
On 3.0L OHV engines, the oil pressure sensor is located on the left side of the engine block above the flywheel. On 3.0L DOHC engines the sensor is located on the left side of the engine block above the oil filter. On 3.4L DOHC engines the sensor is screwed into the oil filter adapter. The oil pressure sensor operates the oil pressure warning lamp.
Fig. 1: Location of the oil pressure sensor-3.0L OHV engines
046f42b.jpg Fig. 2: Location of the oil pressure sensor-3.0L DOHC engines
Fig. 3. The oil pressure sensor-3.0L OHV engine
Hope help with this (remember rated this help). Good luck.
Feb 18, 2010 | 1996 Ford Taurus
Where is located fuel filter
Fuel filter location—2.4L engine
Fuel filter location—2.7L engine
1.5L, 1.6L (VIN 5), 1.8L & 2.4L Engines
Several locations depending on motor size. What is your enigine size?
Feb 06, 2010 | 2002 Kia Optima
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
