Please explain me the error code of Duplo DP A100 printer the error code is: E012 cordially thank you
E012 error on the display what mean
  • berrahma
    berrahma Nov 28, 2014
    thank you for this help but I do not know where I found this interlock
  • berrahma
    if you can send me picture of thise interlock
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
You may need a maintenance kit . Check right side interlock It my be broken.
Posted on Nov 27, 2014
tech435
  • 284 Answers
SOURCE: DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Posted on Sep 30, 2008
tech435
  • 284 Answers
SOURCE: Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Posted on Nov 20, 2008
  • 5 Answers
SOURCE: Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Posted on Sep 02, 2009
SOURCE: please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Posted on Apr 22, 2010
JackHeath
  • 1049 Answers
SOURCE: E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Posted on May 07, 2010
Testimonial: "Thank you. You'd think you'd be able to search for this answer on Panasonic's Industrial site, but I couldn't even find the model number let alone the error code. Thanks for your help. "
Duplo dp-205A scanner open problem
duplo dp-203 problem scanner open
Feb 25, 2013 | Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Hi, how do i find out what the usage of my dp21s is (total copies & masters. alec
No error on the display but when i press on plate making sometimes nothing happens.DP-21s
Aug 27, 2009 | Duplo Office Equipment & Supplies
I haev the error code 04-01
Hello sir; I believed the error you display should be E4-01, if that's correct then folloe the steps to reset it,
1, press and hold following keys by sequence, and continue to hold each while pressing the next, "function","original size", "3".
2, F-1 will display, then go to F9, press "start" enter 06 press start, enter 04 press start to reset.
Mar 13, 2009 | Panasonic Workio DP-2500E Copier
Jan 08, 2009 | Duplo DP460H Copier
Need help
I guess I have to use my psychic powers to see what machine it is.....................................................................................
Canon ...........E020 toner feed problem
E012..................?????? ( not in the canon error code list........E010 & E011 Drive problem)
Feb 08, 2008 | Office Equipment & Supplies
221 people viewed this question
jasbo
jasbo
