Question about Fisher Dryers
My Fisher Paykel gas dryer gets way too hot on the right side. I can only use the lowest setting to dry my clothes. The side with the bearing gets so hot at any other setting, that you can not touch
We have checked the vent hose. We have taken off the back panel to make sure there was not any lint in the wheel. We have also cleaned out the panel on the left behind the lint basket. We have also cleaned the circular lint filter. We have changed the bearing on the right hand side twice already since we have had the dryer due to a grinding noise.
  • Fisher Master
  • 744 Answers
Hello Anita;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I am not sure what components you have in your dryer.
So, these are possibilities:
1.) You may have a bad high temperature limit switch.
2.) Your gas regulator spool valve may be worn or stuck open. There is a setting screw on your gas regulator valve. Turn to the right to reduce gas flow and turn to the left to increase gas flow.
1/4 turn at a time.
3.) Your gas flame tube may have slipped forward or moved redirecting either the flame length or directing the flame at the bearing.
Posted on Nov 24, 2014
2 Suggested Answers
  • 32 Answers
SOURCE: fisher paykel smartload dryer degxius does not dry
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Posted on Oct 15, 2010
Fisher and Paykel dryer dries clothes on medium heat but shuts off repeatedly if I set it to normal dry setting.
you probly have a venting problem disconect the vent from the dryer and try it see if it works ok if so get someone to clean vent ducking out.
Mar 26, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Aerosmart dg62t27dw2 belt squeeking and making clothes stink
Your belt is not on the pulley correctly. You will likely need to purchase a new belt as the damage has likely been done. Remove back cover and then remove casing (video on youtube) Replace belt. You may be able to fix quicker by flipping dryer on side and replacing the belt from the bottom, but it is a tight fit.
Jan 12, 2014 | Fisher Paykel Fisher & Paykel AeroSmart...
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Top load Fisher Paykel dryer doesn't get real hot and therefore is very slow to dry clothes. I've checked the lint filter and the exhaust pipe is clear, so air is moving freely through. It seems it must...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Fisher and Paykel SmartLoad DG62T27G Dryer
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer will run but will not get clothes hot to dry them
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 05, 2010 | Fisher and Paykel DE06 Electric Dryer
Dryer spins - clothes wet?
check your venting as clogged or kinked ductin or venting wil cause long dry times
Feb 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer makes a high pitched squeel when drying
This is caused by the rear bearing for the drum. Have it serviced very soon, as you can save it by applying grease. A new bearing will set you back $40 or so and is unnecessary if you catch it now. . If the front felt runners are worn, have that replaced also. This has to be done or otherwise risk ruining the front of the drum.
Nov 25, 2009 | Fisher and Paykel DEGX2 Dryer
Dryers Logo
Top Fisher Dryers Experts
Tim Whalen
paul
paul
ray gallant
Are you a Fisher Dryer Expert? Answer questions, earn points and help others
