Question about KitchenAid KP50PS Professional 5 Series Stand Mixer
How do I fix my Kitchen Aid Professional 5 mixer that will not change speeds?
It starts fine, but I cannot adjust the speed. It is running fast and throws ingredients out of the mixing bowl.
  • 3,506 Answers
The speed adjustment is defective. You will likely need a service centre if you cannot open it up and find the problem and change any defective parts etc.
Posted on Nov 24, 2014
3 Suggested Answers
  • 4 Answers
SOURCE: My Professional HD Kitchen Aid doesn't mix all of the ingriedienc
One thing many KitchenAid mixer owners complain about is that it's difficult to scrape the bowl while the mixer is running. Because the beater rotates around the inside of the bowl, and because the beater doesn't actually touch the bowl, you have to stop the mixer frequently to scrape the sides of the bowl to make sure all the ingredients are well incorporated.
Two companies have come up with fixes for that problem -- the BeaterBlade+ and the SideSwipe.
They are available for most KA mixers. Cook's Magazine tested both in January 2009 and liked the SideSwipe a tad more than the BeaterBlade because they thought it performed a little better on a particularly heavy cookie dough, but one reviewer on another forum commented that dough tends to bunch up on the SideSwipe's inner parts.
In any case, I have the BeaterBlade+, mainly because it was available from Amazon for $30, no tax, free shipping, and I didn't feel like driving around to find the other.
Both are made of very strong plastic and have silicone scrapers on the edges of the blades. The scrapers do touch the bowl and thus provide a constant scraping of the ingredients, assuring that everything gets mixed in. I've found that I rarely have to stop the mixer, except to make sure that the ingredients that cling to the beater itself are mixed in.
Posted on Jul 10, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
How to replace the speed control plate
Take the back cover off, remove the wires. Unclip the spring from the bottom of the plate, don't let it fly back inside the housing. Unlock the 2 screws at the top and undo them. Fit the new plate, each screw 8 turns in to start with. Hook up the spring, put on the wires where they came from. Start machine on speed one, and adjust the top screws evenly to give the planetary 13 to 15 revolutions in 15 seconds. Lock the screws up with the lock nuts. The screw at the bottom is then adjusted so that it gives a slight speed increase when you enter speed 2 from speed 1.
Jul 29, 2014 | KitchenAid K5SS Mixer Speed Control Plate...
Kitchen aid mixer only goes 1 speed
The number in your question (9706529) is for the worm gear.
What is the model Kitchenaid mixer you have?
Jul 21, 2014 | KitchenAid 9706529 Stand Mixer Worm Gear...
KitchenAid k5a arcing on control board
it was stuck on high speed because the phase control board went out, your fix may not be absolutely 100% and it is now causing an uneven distribution of the electric charge in the mixer and it is arching. My recommendation is to replace the speed control board (black and copper plate) and the phase control board. i bet it fixes the problem as these are the two parts that regulate the electricity in the mixer. Hope that helps. Buy the way if you don't fix the problem and continue to use the mixer you may have to replace the motor eventually as you can cause the armature and stator to short or burn out.
Feb 03, 2013 | KitchenAid K5ADH 5 Quart Mixer Dough Hook...
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 02, 2011 | KitchenAid Classic Stand Mixer
Kitchenaid K45SSWH Mixer only starts fast then sometime slows
You can try adjusting the speed control as shown in section 6 of the service manual:
Also remove and clean the brushes as shown in the same manual pg 8 fig. #30.
Apr 11, 2010 | KitchenAid KP2671 Professional 6 Series...
My Kitchen Aid Artisan Stand Mixer only runs on high speed.
you can try to use some oil free contac cleaner on the speed switch. if that don't fix it put a new speed control switch in it.
Jul 20, 2009 | KitchenAid K45SS Classic Stand Mixer
MIXER WILL NOT RUN AFTER CLEAN/LUBE TEN YEAR SERVICE.
The speed control is a governor setup, it's purely on and off, as the weights on the motor shaft spin faster, they press against the contacts, and when they spin a fast enough speed, it turns off current to the motor, which makes it slow down, and current gets turned back on.  That way, you get a pretty consistent speed on a setting no matter whether it's lightly loaded or whipping something fairly heavy.  If you can turn the motor shaft by hand, then you don't have anything binding, but you might have gotten the speed control out of adjustment.  give it another go.
Sep 21, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KP50PS Professional 5 Series Stand Mixer Logo
107 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
