Question about Garden
Have a 2010 RZT 50", vibrates a lot when engaging PTO
  • 3,506 Answers
Check the universal joints and make sure all rotating parts are properly lubricated and then look at what is attached to the PTO and see what is out of balance in that part
Posted on Nov 24, 2014
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
heatman101
  • 43501 Answers
SOURCE: I have a cub cadet RZT 50 mower deck and my
The problem is the clutch it's self... it is slipping and when it gets too hot it just quits...
The clutch will need to be replaced and that often is not a fun job. You also should have specialty tools to do the job, as they are very hard to get off the shaft many times... the same heat that stops the clutch, almost welds it too the shaft...using heat to free it therefore does not work like it normally would.
Just for giggles a grins, check for power to the clutch after is stops...I think you will find that it is still getting power to it, it just is not engaging or staying engaged anymore...
heatman101
Posted on Jul 14, 2011
  • 6468 Answers
SOURCE: Pto on my Cub Cadet rzt 50 will not engage
check for 12 volts at the clutch plug if no power start checking the safety switches
Posted on Apr 08, 2012
How do you know if it is the switch or the clutch when the blades are not engaging?
if no voltage at pto then go to switch if no voltage there check fuse if power there replace switch if voltage at at pto replace clutch switch cost 60.00 pto 200.00
Sep 01, 2014 | Garden
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Apr 07, 2012 | Garden
When I pull the PTO lever up, it does not engage the blades.
you will need to check and see if the voltage is getting to the pto itself if it is then the pto needs replaced if not then the switch is bad
Apr 17, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
PTO will not engage on my 0 turn Cub Cadet RZT 50. What should I check and how do I check it?
see if the switch is getting power to it and if it is see if the clutch is getting power. it needs 12 volts in order to engage.
Feb 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
