Question about Apple iPod Audio Players & Recorders
How can i play my ipod in aiwa nsx-k950 - iPod Apple Audio Players & Recorders
    Sergeant:
  • 399 Answers
If your Aiwa does not have an iPod connector (30-pin or Lightning), but has an AUDIO IN jack, you can connect your iPod to that jack from the headphone jack of the iPod using an audio cable with 3.5 mm. plugs at both ends.
Posted on Dec 21, 2014
gadget
  • 14 Answers
SOURCE: Power cuts out
This problem happend to my sony system about a year ago. It was the amp that blew in mine because of the fan inside the system was not coming on when it should of. I found that when i had put my PC in the AUX jacks it blew the fan on me, so every time the volume got to 15 the system would just shut down and not come back on at all, or it would need time to cool down before it would start up again. Take it to a shop and get it looked at by someone that knows what there doing. Please dont try and do this yourself.
Posted on Aug 16, 2006
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
SOURCE: AIWA CD Problems
Sounds like the lasers need a POT (potentiometer) adjustment. Tools you will need are a multimeter with Ohms (preferably digital) either a #1 or #00 and #2 philips screwdriver. You will need access to the bottom of the laser. On the units I've worked on the POT faces the back of the unit. It will look like a philips head screw in a square metal casing. You should not need to completely remove the CD tray assembly but you can if you wish though I recommend removing the tray bezel Look for two legs on the side of the POT casing that go to the laser PCB. Measure the resistance across the two legs for an initial reading. On mine it was exactly 1kOhm. Now take the #1 or #00 philip screwdriver and adjust the screw to lower the resistance. POT screws are typically EXTREMELY sensitive so 1/16 of a turn can make a big difference. Start by lowering it by about 20-25%. So if the initial reading was 1kOhm aim for 750-800Ohms and test. You should use several disks for testing. If your unit is capable of CD-R/RW playback then have those available as they are generally more difficult to read. If you have playback gradually increase the resistance 5-10% until the disk is no longer readable or struggles to read. Now lower the resistance again 5-10% and retest. If all works well reassemble and enjoy. It is necessary NOT to lower the resistance too much as it will shorten the life of the laser and if too low could damage the disks. If you must go lower than 25-30% the laser is not worth salvaging. Typically 10-15% is all that is required. If you need more detail I recommend doing a search for 'xbox POT adjustment' as the procedure is essentially the same for all lasers and some xbox sites have good pictures so you can see what your doing before you dive in. Total repair time per unit will be 1/2 - 1hr, mostly spent in all the testing. Hope this helps. Good luck
Posted on Jan 29, 2009
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
AIWA NSX-SZ201 LOOKING FOR USER GUIDE TO SEE HOW YOU PLAY TAPES IN THIS SYSTEM
Here is a link. All you have to do is search on your item and add the word "manual" Aiwa NSX SZ201 Manuals
Aug 30, 2015 | Aiwa Audio Players & Recorders
How can i connect my Aiwa NSX-K950 to LG smart tv
Possible. Connect audio outputs of Aiwa to the audio inputs of LG. You can download Aiwa user manual from the web to see the alternative interconnections.
Jan 13, 2015 | Aiwa Audio Players & Recorders
How to connect aiwa vcr nsx-k950 with mobile phone
I think you may be trying to hook up technologies from two very separate eras, it would be like trying to put an audio cassette in a CD player....
Nov 24, 2014 | Televison & Video
REMOTE CONTROL FOR aiwa model no. NSX-K950
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electrohelponline.blogspot.com/
Dec 30, 2013 | Televison & Video
How can i play my ipod on an Aiea CX-NAJ22?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX.
*It'll be advisable to lower the system's volume, so as to not cause any damage to your system or speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
JaHa
Oct 07, 2012 | Aiwa NSX-AJ310 Shelf System
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
How can I play my ipod on an Aiwa NSX-AJ310?
Turn on your system and then set the function to VIDEO/AUX. It'll be advisable to lower your volume, so that you may not cause any damage to your speakers!!
Hope this helps!!
JaHa
Nov 30, 2009 | Aiwa NSX-AJ310 Shelf System
Good morning, I need your help for my Aiwa NSX-SZ50 digital audio system .... It went in demo mode, what can I do to start again ???? It is possible to have another manual ??? Many thanks for your...
you can order new owners manuals online in many places. Search for Aiwa NSX-SZ50 owners manual.
I would try unplugging it, and then play a cd... it should snap out of it. if not, look through any menus you can access.
Aug 19, 2009 | Aiwa Audio Players & Recorders
Power cuts out
Aug 14, 2006 | Aiwa NSX-AJ205 CD Shelf System
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
