Question about Sony Walkman Audio Players & Recorders
Sony Walkman D-EJ100 Personal CD Player: eats batteries even when not in use. I listened to a CD for 20 minutes, stopped, and a pair of new AA batteries were dead 4 days later. Is there a way to shut
New player in its bullet-proof capsule (found while decluttering the garage.)
  • 2,509 Answers
Probably suffered damp ingress while in storage, and thus some conductive internal corrosion; use a test meter to see if there's any leakage when it's switched off and take it from there...
Either that or use AA Nimh rechargeable batteries
Posted on Nov 24, 2014
5 Suggested Answers
  • 12 Answers
SOURCE: Blinking "disc" error
another thing to do is listen to the unit as it spins up, you may be able to hear the disk spinning (though you can definitly see it if you open it up) and you should also be able to hear the mechanism that moves the optics allong the rail. If you hear that but still no read, you might try opening up the case (6 small phillips screws and then a small bit of prying to open) and look to see if the small thin plastic wireing harness is fully seated in the connector on the main board. If not loosen the small brown retaining clip and push the plastic strap with the traces fully into to connector and push the retaining clip back in. I have fixed 2 d-nf420 units this way.
Posted on Nov 16, 2006
ZEETEC
  • 8 Answers
SOURCE: Sony Walkman D-NS505 Personal CD Player
simply put off the batteries.
Posted on Oct 02, 2008
  • 71 Answers
SOURCE: Sony Walkman D-FS601 Personal CD Player
1. Slap it while it is on but with no disk inside. 2. Make sure batteries touch the metal contacts. 3. Make sure that "hold"(a switch on the side of the player) is not on. 4. are batteries in correctly? 5.if nothing works then chuck it or return it if you can.....
Hope this helps!
Posted on Jan 24, 2009
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
Posted on Nov 14, 2009
I have connected an adapter of 4.5V with Sony Walkman, i am receiving an error "HI DC IN". Let me know the problem.
hi,
check the out put voltage of that adapter may be its out put is higher than 4.5V dc.
thats why the Walkman displays HI dc IN. do one thing purchase a 4.5V 1amps SMPS adapter (connector with same polarity). it will give a constant output of 4.5v (110v t0 240v input)
ok
Jan 19, 2011 | Sony Walkman D-EJ100 Personal CD Player
My sony N50 won't play and reads no disc when htere is one in it. The batteries are fine
It is quite possible that your optical unit is faulty. First of all clean the lens on the optical head using an ear bud, softly rub for a good glazing. then try to see if it works if not the lens unit assembly must be replaced and must be done with care and experience.so take help to replce but make sure the cost is within a practical level. Good day
Aug 09, 2010 | Sony Walkman D-EJ100 Personal CD Player
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Apr 05, 2009 | Sony (Personal Audio) Walkman AM/FM Stereo...
Sony Walkman D-FS601 Personal CD Player will not turn on. New batteries. papa61@bellsouth.net
Hope this helps!
Jan 20, 2009 | Sony Walkman D-FS601 Personal CD Player
Turn walkman off
If it's a tape player with a stop button it should turn off by just pressing stop. If there is a radio then there then there should be an off position where you select if you want to listen to the radio or listen to the tape.
Jan 19, 2009 | Sony Walkman WM-FS399 Personal Cassette...
Sony cd walkman D-EJ100 troubleshooting
Aug 11, 2008 | Sony Walkman D-EJ100 Personal CD Player
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
