Question about Jura Ena Micro 1 Automatic Coffee Center
My coffee machine is dumping coffee into tray every now and then
When i am making a cup instead of putting brew into cup it sends it to tray
    New Friend:
  • 38 Answers
You need a new drainage valve,while you change that you might as well change the orings on the brew group
Posted on Nov 28, 2014
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
B40 WR Keurig shooting out water instead of brewing
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle
Dec 26, 2012 | Keurig Special Edition B60 Coffee Maker
Kerig Vue will not come out of the preheat mode
This worked for me: 1) Turn off machine 2) Remove lower tray. It pulls right out. make sure it is clean. RE-insert. 3) Remove upper tray. It's a little trickier, put it also pulls down and out. Mine was full of coffee grounds. I rinsed it out with tap water. 4) Replace upper tray. 5) Take a used V-cup and take the foil and filter out leaving only the plastic tray. Clean it thoroughly of coffee grounds with water. Replace it in the V-cup insert. 6) Power on the Vue. It should come on pretty quick and say " Ready to Brew" run 6 to 8 oz through with just the blank V-cup. This will clean out any remaining debris. 7) Now put in a new V-cup and brew your coffee!
Oct 04, 2012 | Keurig Vue Brewing System
When i try to brew a large cup it has started brewing small cups instead. I have to brew two large cups to get enough coffee.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 25, 2011 | Keurig B60 Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
When pushing button for a cup of coffee to be made - the beans are grinding and dumping in the box - however no water is coming thru to empty into my cup - the water is being dumped into the reservoir...
Hi
Dry grounds dumped.
There is a lever at the top of the door on the right side. Yours is actually inside the door on the machine. Pull the lever back 1 notch from the plus(+) . You are dumping too much coffee in the brew unit and it can not compress it, so it dumps it, or breaks the drive gears. Never push the lever all the way or it can cause this overcharge. Its fine if the brew group is clean but when you make coffee there is always a residue left and this is what causes the overcharge.
Oct 24, 2009 | Saeco Magic De Luxe Espresso Machine
Cant steam milk and brew expresso at the same time.
You are not doing anything wrong.. that's the way this uint works.
Jan 14, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
/Mirran
Sep 02, 2008 | Saeco Incanto Classic Espresso Machine
Spidem trevi exclusive
you have probably removed the tray during the time the brew unit was transporting the coffee. by removing the tray you stopped the transporting unit halfway in this process.
You can solve this by putting back the brew unit. Close the machine Do not put back the dump tray. Look into the machine, at the spot where the dumptray should go. There is a litte slot in the back. but put a little spoon or some small screwdriver into this slot. You can hear the machine finish the transporting cycle. After that you can put back the dumptray and it should work again.
May 12, 2008 | Spidem Trevi 'Exclusive' Espresso Machine
Jura Ena Micro 1 Automatic Coffee Center Logo
411 people viewed this question
Top Jura Coffee Makers & Espresso Machines Experts
cramsey548
ray gallant
rich2481
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
