Question about Kenmore HE5 Electric Dryer
Replace the heating element
I need to replace the heating element. How do I do this and is there a video I can follow?
    Sergeant:
  • 303 Answers
Here are some results I found on youtube one might help you see how it's done
http://www.youtube.com/results?search_query=Kenmore+HE5+Electric+Dryer+Replace+the+heating+element
Posted on Nov 24, 2014
Instructions for replacing a heating element for a Maytag dryer
Wow, haven't seen one of those in years! If I remember right, the following video should point you in the right direction:
Oct 21, 2014 | Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Miele heating element
sorry - may seem odd - but your hot water tank is set to 120 or higher yes ? so why are you re-heating you water? - if you want to know you need the 2000w /230v - but really turn the re heat off - at 120 you kill the bacteria and will save $$
Mar 20, 2014 | Dishwashers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Samsung dryer not heating
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Mar 09, 2012 | Samsung Dryers
2001 kenmore elite dryer is not heating
Hello there and welcome to fixya
Dec 31, 2011 | Dryers
HOW DO REPLACE THE HEATING ELEMENT OF THE BRADA BED70W DRYER?
There is a video on YOUTUBE on the complete disassembly of the Brada. Follow that to access the heating element for removeal. You can also remove the discharge piping on the back to access the heating element electrodes. remove the wire clips and put an ohm meter accross. you should have some kind of resistance on the meter. There is also a video on how to use an ohm meter.
Mar 08, 2011 | Dryers
My Amana Electric Dryer will not heat up. Model# LE8317W2. We have cleaned out the machine and the vent. I will be purching a heater element (as recommended) is that easy to replace? IS there anything else...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.Here is a video for the element replacement.Here is a video for the thermostat replacement.
Nov 26, 2010 | Amana Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
Kenmore HE5 Electric Dryer Logo
317 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
