Question about UPG 12V 18AH Rascal 110, 120, 370 Fold & Go Battery - 2 Pack - UB12180MP21194
I have inherited a Rascal Fold and Go 370 and have ordered two new replacement batteries to go in the battery case......however, my husband does not remember how the batteries are wired back in the ca
I have inherited a Rascal Fold and Go 370 and have ordered two new replacement batteries to go in the battery case......however, my husband does not remember how the batteries are wired back in the case! Please help. Is there a diagram or some instruction I can refer to? Thank you.
  • 42 Answers
The batteries are wired in series, meaning two 6volt packs are wired nose to tail so they can deliver a full charge, OR they are wired so that both are in parallel, and each pack contains 1 Ampere-Hour of energy at 12 VOLTS and you use 2 packs to get 2 Ampere-Hours of "CHARGE". What your significant other has to get before he connects the wires back up , is a VOLTage METER to verify the polarity of the wires coming from the adaptor. It USUALLY is RED for positive, BLACK for negative........ but not always....... measure to be sure, then double check.
IF it is two 6 volt cells that are connected in Series, then the red of the first pack goes to the RED WIRE of the adaptor, then the BLACK WIRE of the first cell goes to the RED WIRE of the second cell and the BLACK WIRE of the second goes to the BLACK WIRE of the adaptor.
*Your mileage may vary, not intended to give professional advice, all actions are at your risk, Federal Deposit Insurance will only cover cash deposits at Federal Registered Banks. Colours may fade over time. Always call a friend when you need the answer.
Posted on Dec 26, 2014
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
On my rascal fold and go 370 it wont move wires are fine battery are a couple months old but it wont move it turns on and the gage just blinks any one help?
Hi , does it flash a code like 7 flashes etc,,,, or bleep a number of times ?
Regards
Rob
www.gewizrepairs.co.uk
Apr 28, 2015 | Health & Beauty
Rascal 370 wiring schematic
I can't get the wiring schematic for my Pride scooter either.
For some reason these seem to be proprietary and only available
to their dealers. Try monsterscooterparts.com to see if they
can help you.
Aug 30, 2014 | Electric Mobility Rascal Scooter...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
How to open battery case on a Rascal 320
Remove the battery pack from the chair and turn it over. Make sure you do this on a flat surface. I usually put a towel or rag under it. Turn it upside down. You will have to use a Phillips screwdriver to remove the 8 screws on the bottom. Once they are all loose you will have to turn the battery case back over. The 8 screws should fall out. This is the reason for the towel so they don't bounce or roll away. At this point you can lift off the top to remove the batteries. Each battery had a sensor taped to the side. You need to remember their placement and then remove. Then you can remove the connectors from the batteries. You just reverse this procedure to install the new batteries.
Apr 15, 2014 | Health & Beauty
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
On my rascal fold and go 370 scooter the battery is long battery that just slides and clicks into place at the rear of scooter,when i try to order a new battery ,all the dealers keep trying to sell me a...
  1. Two small batteries fit inside the outer case. What you thought was a battery is actually holding two batteries inside it. The batteries you need are not difficult to find.
Dec 30, 2011 | Health & Beauty
I bought a rascal fold and go 370 for my sister because she needs it really bad and I have checked all the wire conections and the battery charger is still at red but has been on for about 8 hours the...
Flashing lights will dinicate what the problem is by the number of bars that are flashing. Here is a website that may help you, if you no longer have the owner's manual. Locate the controller that is on your scooter to dtermine what the blinking lights mean and if the problem can be serviced by you.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 19, 2010 | Health & Beauty
UPG 12V 18AH Rascal 110, 120, 370 Fold & Go Battery - 2 Pack - UB12180MP21194 Logo
848 people viewed this question
Top UPG Computers & Internet Experts
Richard416282
Marco De La Fuente...
Tom Chichester
Are you an UPG Computer and Internet Expert? Answer questions, earn points and help others
