Question about Masterbuilt Turk-'N'-Surf's Turkey Fryer
<!-- from fixya rte -->Why does it prematurely shut off? - Masterbuilt Turk-'N'-Surf's Turkey Fryer
Have a blodget dfg-50 oven that will intermittently shut down both the heat and blower at the same time, will restart itself after a period of time.
Either it is overheating and shutting down or the mechanism that regulates the internal temp is faulty and just shutting down prematurely.
Sep 26, 2016 | Ovens
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Compressor shuting down
Either the thermostat is prematurely shutting down the compressor or the latter is overheating and the clixon is shutting it down.
The defrost timer also will shut down the compressor and all fans but that is only once every 10 hours or so to defrost unit. In about t10 15 minutes the timer will turn the compressor back on.
Sep 09, 2015 | Refrigerators
Why does my bobbin winder stop prematurely?
Define "prematurely". Bobbins shouldn't fill to the edge of the bobbin. Are they wound evenly? Uneven winding can cause the winder to stop early.
Aug 24, 2014 | Singer 3116 Simple
Dryer gets hot, outside vent seems to have plenty of air coming out. Lint screens all clean. But the unit takes two cycles to dry and in the past it always dried in one cycle. Whats wrong??
Is this happening on automatic dry cycle or timed drying?
It sounds like your moisture sensor is "confused" and shutting down heat prematurely.This part can be replaced.
Also double check your exhaust vent for blockages or standing water or sagging or open pipe
Also , your heater element may be shutting on or off prematurely. Could be a high limit thermostat problem. Or there is obstuction causing over heat
hope this helps
Aug 15, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Colours have gone and picture quality became very dark. Now wont stay on for very long...will switch off after about 10 mins of viewing.
Unfortunately dim image and premature shut-off are normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image/premature shut-off.
Aug 01, 2011 | Panasonic PT-AX200U Projector
Eden pure heater starts to heat then elements shut off i replaced thermostat and heat sensor any other suggestions what to try next
yes u have overheatsensors that shut the strips down if they get too hot these may be going bad and getting weak and shutting off prematurely
Feb 20, 2010 | Reddy Heater R70 Portable Forced Air Space...
Dryer runs and heats but shuts off prematurely
It could be the timer or the sensor as well. Before replacing parts, it may just need a cleaning. If you are not familiar with the product then you should call a professional. The dryer is designed to shutoff when it is overheating, which as you stated it heats up nicely, but shuts off.
Lint, the unfortunate result of drying gets on the sensors and other parts and causes them to react prematurely. If you haven't cleaned the unit, it may just need that, if not I would then say start looking at replacing parts. For safety concerns, you should have your dryer cleaned yearly.
Another thing to check is the exaust for kinks or blockage, when this happens it causes heat back into the unit and again shuts it down.
Give those a try and it may just solve your problem.
Thanks,
Paul
My Website
Jan 28, 2009 | Kenmore 63942 Dryer
Shutting Off Prematurely
may be highvoltage circuit or high voltage diodes, or mains power problem, check the control unit.may be magnetron..
Sep 25, 2007 | Panasonic NN-S634 1250 Watts Microwave...
Masterbuilt Turk-'N'-Surf's Turkey Fryer Logo
59 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
