Question about Mitsubishi LT-46144 46 in. LCD HDTV
Mitsubishi LT-46149 power lamp just flashes and tv will not turn on. Tried the reset and unplugged overnight, also I do wait for the "boot up" still just have a flashing power lamp. Any ideas?
Tried unplugging and waiting overnight also reset button, still just have a flashing power lamp. Television was manufactured in October 2008 but only very little use, possibly only 200 hrs or so
    Top Expert:
  • Mitsubishi Master
  • 75,157 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 24, 2014
Testimonial: "Thank you for the reply. The set will not power up at all so checking for fault codes is impossible. When the problem occurred the set was off and I could hear the main relay clicking, then I noticed the power lamp flashing, the only way I could stop the clicking and flashing was to unplug the power cord, after plugging the set back in, all I have now is the set not powering up and I just have the continuous flashing power lamp. The main board faulty? That sucks, looks pretty easy to replace though. Mark"
  • Mark Fruciano
    Mark Fruciano Dec 08, 2014
    Hello. I would like to update on the repairs. Located a replacement main board on e-bay, arrived yeaterday, replaced the board and now the television works perfect! for $65.00 and some patients the television is functioning as new. Thank you for the advise. Mark.
2 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: On a mitsubishi tv (LT-46149)
It is possible that you have a bad power supply, or the TV has been hit by a small power surge and if you unplug the set from the wall for 40Min., it will rest back to normal.
Posted on Feb 06, 2011
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Hi Since that did not work, The next thing is you have to take the back off the TV and find the main power board. On that board there will be some bad capacitors. Look for bulged or leaking CAP(s).
Replace them with same capacitors types. If you're not tech. savy Go to TV repairman. Good luck.
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Misubishi LT-46149 solid red light
Your TV is on stand by., you possibly have power supply board problem or main board.. you have to call a service
Jan 14, 2013 | Mitsubishi LT-46144 46 in. LCD HDTV
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
On a mitsubishi tv (LT-46149) the manual intructs us to wait exactly one minute for the LED green light to stop flashing and then its alright to turn on the tv, the problem is that the light wont stop...
Feb 06, 2011 | Mitsubishi Televison & Video
Mitsubishi LT-52148 lcd tv turns on for 2 seconds with sound and shuts off.Tried resetting.What could be the problem?
The lamp LED indication flashes?When was the lamp replaced?The lamp has not been replaced 1 1/2 or 2 years.The lamp life is over.Require a new lamp.
Sep 01, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
Mitsubishi LT- 46149 LCD TV turns on with pic then pic blacks
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 11, 2017 | Mitsubishi LT-46149 46 in. HDTV LCD TV
Mitsubishi LT-46144 46 in. LCD HDTV Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
