Question about Dryers
<!-- from fixya rte -->How do I get to the heating coils - Dryers
    Sergeant:
    Champion:
  • 214 Answers
The ones I have seen have to have the back taken off. Please remove the power from the dryer before working on it. 240 VAC hurts!
Posted on Nov 24, 2014
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
I have a beko dcu9330 dryer givin n heat. changed blown sensor and tested both sesors, still no heat, no power getting up to heater. whats next step?
Electric dryers have a heating coil over which air is drawn to heat it up. Unplug your dryer and use a continuity tester to check the heating coil for breaks. Attach one lead to one coil terminal and the other lead to the opposing terminal. No reading indicates a burned out coil (very common). All coils are replaceable.
Oct 22, 2014 | Dryers
My sq inverter works on cold air but when changed to heat stops working
Some models don't use the compressor as a heat pump for heating. And only use electrical heating coils in the heat cycle.If yours is one of those. It may be a burned connection at the thermostat or at the heater coil. Heater coils may have a safety diode or fusible link that opens if the heater coil is on but there is not enough airflow. If that is the problem you will need to remove the bad heater coil and replace it.
If your unit is a "true" heat pump the change over valve could be stuck or it's coil burned out. If you know what it looks like you can measure the voltage at the coil. If you have voltage sometimes you can whack the valve with a screwdriver handle to "unstick" the valve.
Jul 11, 2012 | LG Heating & Cooling
The heating coil looks fine, however i am not getting any heat. Where is the thermal fuse? Could this be the problem?
Sorry to read about your problem.
Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. if you pulled the covers to look at the heat coils. you must meter the coils. the thermal switch is close to the coil line.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Dryers
TUMBLE DRYER NOT HEATING UP
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
No heat
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 16, 2009 | Whirlpool GEW9250 Electric Dryer
WONT HEAT, DRYER WILL TURN BUT WONT HEAT UP.
Good Luck,
Hope this helps
Oct 13, 2009 | Maytag PYE2300AY Electric Dryer
The dryer does not heat up, it starts and everything, but no heat
Sounds like your problem is with the heating coil.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
Good Luck,
Hope this helps
Oct 07, 2009 | LG Dryers
Dryer has no heat.Changed the heating coil rear
Maybe you already know this, but occasionally the coils will swell when you first turn them on and they expand to the point of arc'ing off the housing. This puts you right back to square one. I learned the hard way to buy the entire assembly when changing and not just the coil. Not sure if this is your problem or not, but worth another check. I believe the next step would have to be in the control system.
Aug 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
