Question about Magnum 2007-2008 dodge 3.5l v6 a/c compressor clutch
My 2008 dodge magnum 3.5 it has a delay once you turn the ignition it had a 2 to 3 second delay an got to 5 an 10 seconds it recently gotten worse to 30 to 60 seconds now it starts when it wants to
Took it to the shop once i got it started an it started up everytime for technician
  • 3,368 Answers
Take it back to the shop!
Posted on Nov 26, 2014
2008 dodge magnum has a few second delay, sometimes longer or not delay. battery has been checked and it is fine. could it be the starter relay fuse?
More likely it's the solenoid that pushes the motor gear into the flywheel. The solenoid turns on the motor once the gear is meshed to the flywheel. Replace just the solenoid. Don't let any one talk you into a new starter.
May 30, 2014 | Mitsubishi Electric Automotive 2005 - 2008...
I have a 2006 dodge magnum 2.7 with 136k miles, I changed the coil pack, spark plugs & a new throttle body all OEM parts... Once the car warms up my idle drops to 625-700 but it feels like it wants to...
Hi Gabro
try this procedure and let me know if it work.make sure the engine is in normal temperature, all accessories are off.
start the engine and let it idle for 1 minute.
put the selector into D and let the engine idle for 30 seconds.
turn the AC on and let the engine idle for 30 seconds.
turn the AC off and let the engine idle for 30 seconds.
put the selector into P and let the engine idle for 30 seconds.
switch engine OFF for 2 minutes.
Feb 04, 2014 | 2006 Dodge Magnum
I have a 2-3 second delay went i turn the key . For 1 week .
Have the battery tested even if you think it is ok, Autozone does this testing for free you have nothing to loose and i think you have a battery issue here.
Oct 02, 2012 | 2008 Dodge Magnum
05 Dodge Magnum went from 60 - 0mph in 0.0 seconds flat!!!
Sounds like you need a new key to me. When they start and die like that, the security system is not seeing a good key. This has to be done at a Dodge or Chrysler dealership. They can cut a new key and fob combo their as well as program them with their scan tool. It will cost about $200.00 to do this. The two cranks to start is a weak fuel pressure regulator. Probably located on the the fuel pump. May be serviced seperate now from the fuel pump assembly. Ask the dealer they will know.
May 20, 2012 | 2005 Dodge Magnum
Resset my oil change dodge caliber 2008
1. Turn key in ignition to "On" without starting the car...
2. Depress accelerator fully 3 times within 10 seconds
3. Turn key in ignition to "LOCK".
on number 2, do it slowly all the way to the floor but within the 10 seconds
Jun 23, 2011 | 2008 Dodge Caliber
Change oil light keeps coming on even though oil just changed
Page 177 of your owners manual.
1. Turn the ignition switch to the ON position (do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
Nov 23, 2010 | 2008 Dodge Caliber
07 dodge cummins perform service how to reset
Hello rjessop.
Here you are.
I think you are speaking of the maintenance light.
If it doesn't clear the first time you may need to repeat it.
  • 1. Turn the ignition switch to the ON position (Do not start engine).
  • 2. Fully depress the accelerator pedal slowly three times within 10 seconds.
  • 3. Turn the ignition switch to the OFF/LOCK position.
Thank you for using FixYa.
KL
Mar 21, 2010 | 2008 Dodge Ram Pickup 2500
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
Grinding noise about 30 seconds after starting
Sounds like starter isn't disengaging, get that checked pronto, you could be damaging the flywheel (very expensive). Could be any appliance also; a/c compressor, idler pully, alternator, etc. Don't wait.
Jun 10, 2009 | 2007 Dodge Charger SRT8 Sedan
3 second delay (when warmed up trans engaging from park to drive
thats a deff. tranny prob. theres a fluid transition prob when it goes to buildup... almost like air brakes
Feb 28, 2009 | 2005 Nissan Frontier
Magnum 2007-2008 dodge 3.5l v6 a/c compressor clutch Logo
62 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
