Question about Broan-NuTone (8663RP) Ceiling Fan
How do I purchase a grille for my fan. thanks e17814
The spring connector that holds the spring on broke.. it's a plastic .
  • 601 Answers
If you know the make and model which should be somewhere on the unit. You can find online or in phone book a local dealer of that unit. Call or better yet go there with your broken part, and they can probably get for you what you need. If your unit is old possibly you would be better off replacing old unit with new one. GOOD LUCK FRIEND.
Posted on Nov 24, 2014
I cannot get the spring clips to work in the slots that the diagram shows, therefore I cannot get the grill in place
I have the same fan. Not easy to do, but squeeze the two spring ends together and slip in proper hole, one on each side of fan. Once this is done, push cover straight up and into position. The springs separate once the grill is raised and in doing so, they hold the grill in place. A bit difficult to pull the grill back down to replace bulbs, but holding grill close by the springs will help.
Sep 15, 2010 | Broan-NuTone (8663RP) Ceiling Fan
Can't get the cover off to change the light bulb
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
May 20, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I remove the cover
May 10, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Installing the NuTone C370BN
Sometimes it takes just the right wiggle and jiggle of the spring wire. And holding your tongue just right. LOL
In the past, I have had to slightly push up while squeezing the wires and continuing to push up halfway.....then work the other side. I agree, as simple a task as it appears to be, it can be quite a bear!
I'm including a copy of the installation instructions......you probably have them, but just in case.
Good Luck to you!!!!!! :-)
Mar 13, 2010 | Heating & Cooling
My window rocker switch for the drivers window broke - is it hard to replace myself?
The 2005 is an easy one as MNfisherman posted, no screws with it.
The outside of the panel has 2 spring clips holding it in place, use a plastic trim tool, or plastic putty knife to pop up the spring clips. I insert the trim tool, and turn it clockwise to pop it up. First time will be hard.
Once the spring clips are released, pick up on the outside of the panel ( to release the tabs ) and pull towards the inside to remove.
This is what the back of it looks like
I remove the speaker grille prior to this, to provide more room when removing the switch panel tabs, but some have had good luck without removing it ( your call ).
The grille is mounted with plastic tabs, start with the "point" area at the bottom, and pry out, and work your way around if you want to remove the grille.
Nov 23, 2009 | 2005 Ford F-150
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
The light and trim ring will not connect to the vent box, no instructions came in the box, i went online and the instructions did not tell you how to install the trim!!
The two "V" springs on the grill/globe need to be squeezed together and both pieces of one spring are run through one hole and the same for the other side. But it can bite!!
Be sure to keep the grill/globe pulled down so just the hooks of the springs are inside the fan chassis/box. Push the grill/globe upwards. As the springs go through the hole the will spread out and that action is what holds the grill/globe in place.
Oct 25, 2009 | Broan-NuTone N-8663RP Combination Light...
I dropped the dome and broke the plastic handle
I ordered a couple replacement parts for this grill @ Fox international including the handle. Call them @ 1800-231-9786, and choose the option for the George Forman Grill. They claim to have every part for this grill.
Aug 17, 2008 | George Foreman GGR50B Grill
Broan-NuTone (8663RP) Ceiling Fan Logo
117 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
