Question about Kitchen Appliances - Others
What is error Code 3 52 on westinghouse induction cooker. i used a steamer to clean the edge and water must have gone in
5 Suggested Answers
early1234
  • 871 Answers
SOURCE: steamer/rice cooker
you can put at least 3 glasses of water.(depends on how big your glass is).
its up to your prefernce when you want to put the food. but it much better to put the food when the water starts to boil.
hope this helps!
cheers!
Posted on Jan 16, 2008
jhooker06
  • 5 Answers
SOURCE: No manual or instructions
I know the exact model you are talking about! I have one myself....Basically it is always two parts water to one part rice using the same measuring cup to measure both! So if you decided to use it for 6 cups total it would be 4 cups of water and 2 cups rice.....As for veges, You would fill the bottom of the inside pot just enough to where it doesnt touch the other pot that goes inside with holes to hold the veges and you can add a little salt, But then you close the lid and press the cook button and when it finishes it makes a quick and easy dinner side!
Posted on Jul 01, 2008
bdwebb
  • 9 Answers
SOURCE: rice cooker
To practice, add i cup of rice to cooker, and then 2 cups of water (water should cover the rice 2 times over. You can add salt if you wish, then turn the cooker on and when it goes off, it is done.
Posted on Nov 18, 2008
SOURCE: no instruction book for rival rice steamer cooker
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
Posted on Apr 09, 2009
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Convotherm oven error code E03 please can you help
PLEASE READ THE ERROR CODE LIST FROM YOUR MANUAL IT WILL BE SOLVED BY YOUR SELF OR CONTACT US
Nov 05, 2013 | Cleveland Range Cleveland OGS-10.20...
When have weight on induction cooker cooker can not cook
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel)
Oct 02, 2013 | Winco Professional Induction Cooker -...
Induction cooker
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel) If you have the correct pots then it will need a repair.
Sep 25, 2013 | Winco Professional Induction Cooker -...
Eo error code
CHECK DISH, CHECK CAPACITORS IN CIRCUIT,CHECK COIL
Jun 19, 2013 | Winco Professional Induction Cooker -...
SENSOR MIGHT BE OPEN OR SHORT WHICH IS PLACED ON TOP OF INDUCTION COIL.
May 25, 2012 | Winco Professional Induction Cooker -...
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Rice cooker
Nov 04, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
43 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
