Question about Cell Phones
Why won't my LG mach turn on without back cover
    Problem Solver:
  • 18 Answers
This is most likely because the back cover holds the battery securely in place, Most phones won't operate without the back cover on them.
Posted on Nov 26, 2014
I lost the back cover and my LG MACH won't turn on how can I turn it on without the back cover
LGMach seems to be a smart phone (above title is air-conditioners).
However, if the device won't turn on without the back cover, perhaps there is a small micro switch which needs to be pressed ( a small piece of tape/chewing gum might do it), or else there was some kind of electrical contact strip on the cover that needs to touch/make contact between two points on the circuit within the main body (sometimes the battery needs to be pressed by a cover to work properly in tiny products, even if it is not actually a contact strip). Otherwise there is some other sophisticated high tech wizardry that is hidden within the cover tat may not be able to be duplicated so easily. Good luck.
Nov 24, 2014 | LG Heating & Cooling
I losted the back to my LG MACH and now it won't turn on how can I turn on phone without back
It may not be the fact that you lost the back, but if it is, order a replacement.
Nov 24, 2014 | Cell Phones
My lg mach lost back and won't turn on
Check around the back of the machine. There is probably a micro-switch that needs to be closed before the machine will run.
Nov 24, 2014 | Washing Machines
Do I need a back for my lg mach to turn on
Yes there is a switch that the back must come into contact with in order for the unit will turn on.
How do I my wedding ring out of my washing maching, it fell in there last night, on the top part between the lid and the top back part
If it fell between the bole and the housing the cover will have to be removed. if it can be turned upside down it may fall out. If it is inside the bole it may be under the agertater or or in the water pump housing.
Jul 18, 2014 | LG Washing Machines
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
Mach 3 cyclone hoover vac
I have a MACH 3 Cyclone that is only a few months old that just suddenly stopped working and went totally dead like there was no power going to it.
I tested the power switch and noticed that there was no power running to the switch.
I then noticed that the switch sat on top of a very long adjustable handle so I figured I would check the pwer connection at the base of the handle.
1) I unscrewed the 2 screws closest to where the power cord goes into the vacuum.
2) Pulled the small blue cover partially out (it wouldn't come out all the way)
3) I found that there is a power cord (looked like a really small extension cord) that runs through the inside of the handle. Adjusting the height of the handle must have made it come uplugged at some point. I plugged this cord back in.
4) I reattached the small blue cover and screwed the 2 screws back in.
This fixed the problem.
I am willing to be that this is a common issue with this vacuum cleaner. Its a 5 minute very easy fix and strongly suggest checking this if your vaccuum suddenly goes completely dead without warning.
Dec 11, 2007 | Washing Machines
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
