Question about Maytag Neptune MDG5500AW Gas Dryer
May tag gas dyer propane smell when it is off
    Sergeant:
    Champion:
  • 214 Answers
I would get it inspected as quickly as possible, that seems like a gas valve or line leaking.
Posted on Nov 24, 2014
Weber grill will not light
you have to narrow down the problem.when you turn the propane on first at the tank (make sure lid is OPEN) and then turn on the burner control are you smelling gas ? If yes then its simply ignition (BBQ lighter to light manually) if no smell are you sure there is propane in the tank ? Can still feel like fuel inside when empty.if you smell gas but won t light check your venturi valves for spider nests,etc if it sat outside for the winter.it will stop the propane from coming thru the burner.Good luck (my money would be no fuel ) please let me know !
May 05, 2018 | Weber Grilling
Why is there a strong gas odor?
Suggest you turn off the gas supply immediately! and check for a poor connection or other cause. Do not attempt to light the pilot again until the cause of the leak has been found and repaired!
Nov 19, 2015 | Home
I have a full propane gas cylinder for my grill in my garage. It is very cold in the garage and I'm getting a propane smell. Does the cold effect this or is there probably another problem?
Cold shouldn't present any special hazard to a propane cylinder. Just make sure the valve is fully off. You can check for leaking with a little soapy water solution around the valve - look for bubbles. If any doubt, remove from enclosed space.
Jan 08, 2015 | Grilling
Smell of propane
call the company back explain to them about the smell and where you smell it and would like another test of the lines and appliances that are hooked up as to your medical seek a doctor
Apr 19, 2017 | Heating & Cooling
Smell propane after I ran out and filled it back up> I replaced the regulator behind the stove but still smell propane
It is not uncommon to "smell" propane when you run out. Propane has an odorant called mecapitan added to it so you may detect it. When you get low or run out the mercapitan is typically in greater volume than the gas itself. Once you refill, you will also smell it temporarily. Check all connections for tightness and leaks, use a leak solution, and if all is well, start it up and monitor it. The odor should dissipate. If it does not, contact your local licensed propane technician.
Jan 16, 2014 | Tappan Kitchen Ranges
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
CHANGED ORFICE FITTING ASSEMBLY ,NOW FLAME IS YELLOW AND SMELLS.
hi!!! It seems that you have poor gas combustion..It your are changing it too propane make sure you installed them correctly and that the orfice are the right ones for that machine..If yes remember propane gas does smell and flame is yellow..Good luck..
Jan 03, 2009 | Jenn-Air PRD3630 Dual Fuel (Electric and...
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
Maytag Neptune MDG5500AW Gas Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
