Question about Sewing Machines
Sewing machine grinding and needle won't go up and down without force. Air and cloth cleaned what I could.
  • Sewing Machines Master
  • 665 Answers
THIS IS HARD W/O BEING THERE. ANYWAY HERE ARE SOME IDEAS:
1. REMOVE BOBBIN, CARRIER AND CLEAN AREA. OIL IN THE RACE (UNDER WHERE THE CARRIER GOES)-ONE DROP ONLY. TRY TO HAND ROTATE. IF IT IS OK THEN THE BOBBIN CARRIER WAS INSTALLED WRONG.
2. MOVE THE NEEDLE BAR BY MOVING THE HAND WHEEL. PLACE ONE DROP OF OIL ON THE BAR.
3. REMOVE THE TOP OF MACHINE AND MONITOR ALL MOVING PARTS AND CLEAN (USE QUE TIP). ANY PARTS STUCK TOGETHER MAY NEED A SMALL AMOUNT OF CARBURETOR CLEANER. OIL ALL MOVING METAL PARTS THAT MAKE CONTACT WITH EACH OTHER.
4. UNDER THE MACHINE REMOVE THE LID AND CLEAN AND OIL JUST AS ABOVE.
5. TRY TO MOVE THE HAND WHEEL.
6. IF THIS STILL DOESN'T WORK THE BELT MAY BE OUT OF ALIGNMENT. THE BELT HAS TO BE DONE BY REMOVING THE HAND WHEEL. ONCE THE BELT IS ACCESSED THE BOLT UNDER THE MOTOR IS LOOSENED. IF POSSIBLE TRY TO APPLY THE FOOT PEDAL A LITTLE WHILE ADJUSTING THE BELT. IT SHOULD NOT BE REAL TIGHT BUT MUST BE IN ALIGNMENT. PAY ATTENTION TO THE AMOUNT OF TURNS IT TAKES TO REMOVE THE OUTSIDE SHINY PART OF THE HAND WHEEL SO IT IS EASIER TO SET IT PROPERLY.
Posted on Nov 24, 2014
  • 323 Answers
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Posted on Jun 12, 2008
bilabon
  • 46 Answers
What is the length set at?
Are the feed dogs visible at the needle plate?
What does the design look like in the pattern box?
Have you tried it on the straight stitch to see if is effected also?
Bonnie
Posted on Nov 06, 2008
SOURCE: CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
This happened to me and I discovered that my presser foot was stuck up. (LOL) I was using embroidery and the needle was actually brushing against the raised presser foot. So, I turned machine off, removed embroidery part and checked the presser foot switch. It was not moving. Well, I put the machine on regular sewing and just turned the wheel a few times and the presser foot reset. When I went back to embroidery all was fine (and still is). so, check yours.
Posted on Dec 26, 2008
SewTechWayne
  • 186 Answers
SOURCE: Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
Posted on Jan 30, 2009
  • 3741 Answers
SOURCE: Kenmore 158.1703 sewing machine - needle not going up and down
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!. also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 05, 2010
I get a error of, please check upper and lower thread breakage or empty bobbin. I changed thread, rethreaded. I have oiled, cleaned with air. after oiling I ran without a needle, and bobbin.
The thread sensors may be dirty with debris or finger prints..
FWIW, compressed air is not good to use on a sewing machine (although it is frequently recommended). The air forces the debris further into the interior of the machine where only a technician may be able to clean.
Dec 14, 2017 | Sewing Machines
How do I clean the bobbin housing from all the fluff
A soft brush like a makeup brush will clear out the excess fluff. Remove bobbin case first. Or a can of pressurised air as used on computers.
Jun 07, 2015 | Sewing Machines
Brother cs 5000h is totally jammed, hand crank won't turn, needle stuck in down position
I would totally remove the bobbin apparatus & check that area
Oct 09, 2017 | Sewing Machines
Grinding noise and needles breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
since there is a grinding noise it would be a good idea to have the
machine checked
Sep 25, 2012 | White Sewing 1740 Mechanical Sewing...
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
My needle is grinding on my sewing machine
replace the needle first. if does not fix it, then remove and replace your bobbin and bobbin case. After that I would take it for repair.
Jul 17, 2010 | Singer 7442 Mechanical Sewing Machine
My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
May 05, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Kenmore Model 16221 sewing machine
your machine needs to be clean take it down clean and oil it up and you will have that problem no more.good luck.
Jun 03, 2007 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
136 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
