Question about Behringer Xenyx X2442usb Usb Audio Mixer
Do you have a internal power supply for berhinger x2442usb ?
    Sergeant:
    Champion:
  • 214 Answers
Can't it be repaired?
Posted on Nov 24, 2014
How do I set Connect my Boss ME 30 effects peddle .I have a berhinger xeney mixer .Do I need two amps
Try using the insert in/out for the channel you want or the main insert in/out for all channels
Dec 11, 2014 | Boss Music
Separate inputs on xenyx x2442usb using logic pro 9
Unfortunately, the Behringer Xenyx x2442usb only comes with a stereo USB interface. The documentation is a bit misleading, but you can only record two channels through the USB interface - the main mix L and R. If you need to record more inputs than that, you'll have to do them separately.
Mar 03, 2013 | Behringer XENYX X2442 USB Mixer
Monitor mix of x2442usb
Hi Mark, I mailed Behringer and they sent me details of how to do it. If you mail me at seanflynn40@talktalk.net I'll forward it on to you. It looks really complicated to get a stereo signal through but I just use mono signal and its simple and works really well
Feb 27, 2012 | Behringer Xenyx X2442USB / Harbinger...
On more than one occasion my x2442usb, makes a loud static like sound coming from no apparent individual channel but its just there. is this a flaw in the mixer should i send it back?
First, make sure ALL interconnected equipment is POWERED from the same receptacle.
Second, if the sound is routed through your computer via USB, make sure ALL background programs like wireless internet connection, anti-virus, anti-spyware, popup blockers are DISABLED.
These system hogging programs can interrupt the flow of the sound data causing static like noise.
Also use balanced lines for ALL audio interconnects... eithe XLR or TRS cables.
Dec 17, 2010 | Behringer Xenyx X2442USB / Harbinger...
I have Berhinger 1680s powered mixer I have 2 Mackie 350 V powered speakers Can I hook them up? How do I?
Thought I answered this. Using balanced TRS cables, connect the powered speakers to the Main L and R 1/4 inch jacks on the top of the unit.
Nov 27, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have windows 7 and the fca 202 berhinger and i can't find the driver to active
Try installing the driver again using compatibility mode, set to Windows Vista. Alternately, you can right click and chosse check compatibility, or it's worded something like that. Windows will tell you what mode (Vista or XP) to install it in.
May 20, 2010 | Behringer F-CONTROL AUDIO FCA202 External...
Behringer Xenyx 1622FX. Power supply has failed, no +5V rail, other rails are OK, appers to be no input to the regulator. Could do with a circuit diagram. I believe the PSU is used in other mixers.
Suspect a broken circuit trace or broken solder. If they use a 7805 three terminal regulator, check the solder around those pins...
Berhinger does NOT release schematics except to their service facilities... I know... I have tried... I repaair a lot of their stuff and have to trace out the circuits.
Power supply circuits are rather easy except for the switching regulators if they have failed totally.
If only the +5 is dead, you should be only a filter cap and a diode or two away from the problem... Transformer leads and electrolytic leads with their weight are favorite to pull out of solder... On Behringer, often the traces are narrow and can have a crack in them.
Jan 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Xenyx X2442usb Usb Audio Mixer Logo
221 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
