Question about Blazer S10 2002 02
When i put gas into the tank.it won't take it. i replaced filler neck but not rubber hose to tank. still won;t go. any ideas?
Just asked in first question
  • 20 Answers
Sounds to me like someone has played a nasty prank on you and stuffed something down your fuel hose. Get on old metal hanger and straighten it out to gently poke down the refuel hose. There may just be something jammed in there.
Posted on Nov 24, 2014
Testimonial: "we put new filler tube on, so its not plugged. thank you though."
When adding gas in the Jimmy gas is pouring out from line.
You best replace the filler neck so it wont leak, and operate properly. I do not think a vacuum, vapor lock has occurred.
May 24, 2016 | Cars & Trucks
How to replace fuel tank filler tube?
Brother John, you've removed as much as you can for access to the filler. Remove the hose clamps/bands that secure the fill tube and vent tube and then remove the screws around the gas cap that secure the fill tube to the body. With the gas cap off, go below and pull the hose and filler neck down and work the hoses lose with a pair of channel lock pliers and sticking a screwdriver between the metal tube and hose to break the seal. Put on the new filler neck and stick it back up in the body and put the screws back in. THEN put the hose clamps back up and tighten them, put the gas cap back on and your done.
Nov 30, 2014 | 2000 GMC Jimmy
How do i remove the hoses from my gas filler neck
I do not have experience with a Durango. I have experience with a Chevrolet. The hose on the filler line was large diameter and very hard. It would not slip off. I had to empty the gas tank, cut the large hose, and remove the small hose. Then I had to jack up the car, and lower the gas tank to the ground to have room to work. From there is was simple to remove and install parts, install the gas tank, and tank up.
Nov 30, 2014 | Cars & Trucks
How do i replace the neck on my gas tank
1)Open the gas door and unbolt the gas filler neck from the body of the vehicle, using a 1/4-inch ratchet and socket.-------
2)Crawl underneath the vehicle, and use a flat-head screwdriver to disconnect the fuel filler neck from the gas tank. There is a hose clamp that secures the rubber hose to the tank, and a breather tube as well. Work the tubing off the tank using your hands.--------
3)Pull the gas filler neck out of the gas door by hand. You may need to twist it around to snake the tubing through the body of the car, but it will come out.------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | 2001 Oldsmobile Aurora
Gas takes forever to drain into filler tube when gassing up at the pump
check to see if theres any objects in the filler tube. If you have small children they can find a million things to do to that van
Feb 03, 2010 | 2005 Dodge Caravan
Gas filler neck replacement
open the fuel cover and remove the bolts.Remove the ground strap from the filler tube from under the car.Remove the hose clamps to the rubber hose going into the tank and pull off the hose.Now the filler tube will come out[ if has'nt already fallen out and hit you in the head].
Nov 18, 2009 | 1997 Oldsmobile Cutlass Supreme
Gas leak on fuel filler neck, how can I fix this?
if it's a hose or pipe go to dealer or junk yard get another if broken clamp replace if neck part of tank call rad shop see if the can solder if you drain & pull tank
Aug 30, 2009 | 1995 Buick Regal
Gas cap is contacting inside of filler neck
YES IT CAN FROM THE RUBBER HOSE UP TO WHERE YOU PUT THE GAS IN
Aug 07, 2009 | 2007 Mercedes-Benz E320 BLUETEC Sedan
1995 maxima fuel filler tube
Are you going to get a new one, or a junkyard replacement?
You have to take off the rear left tire. Secure the car with jack stands and chucks. There is a plastic cowl on the wheel-well that covers the filler tube to prevent road damage. Take it off. The filler tube is attached to the gas tank through a rubber connector hose (tube) adapter, secured to the gas tank and to the filler tube by hose clamps. Loosen both clamps.. You should replace the rubber connector, as it has been there for many years, and rubber degrades. Loosen about three or four bolts along the filler tube that attach it to the car body. The top part, by the gas lid, comes off easily, it's just a plastic dam. You have to carefully work it off the (other end) at the rubber hose connector. Once it's out, get the hose connector off the gas tank neck.
With the new filler tube, reverse the process. Getting the hose clamp tight over the gas tank neck is hard. Make sure the clamp is seated properly before tightening.
Oct 30, 2008 | 1995 Nissan Maxima
Blazer S10 2002 02 Logo
42 people viewed this question
Top Blazer Car Audio & Video Experts
xxxxxx xxx
Are you a Blazer Car Audio and Video Expert? Answer questions, earn points and help others
