Question about Pride Health & Beauty
When turning on my jazzy 1113 ats the first four lights in the battery strength blink rapidly, chair wont go
Tried turning on & off, pushing horn button, unplugging & replugging
  • 47 Answers
4 flashing lights fault code tells you that the right motor has a bad connection. Check and make sure that the right motor is engaged and that it is plugged in properly. The code says that the wiring to the right motor or the right motor itself is bad. The fault codes aren't always right and it could be a problem in the joystick controller itself.
Posted on Nov 26, 2014
Testimonial: "we switched control heads with another old chair. it worked!!"
  • 38 Answers
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Posted on Dec 30, 2008
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
  • 175 Answers
SOURCE: jazzy 1113 will not charge,
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Posted on Jan 08, 2010
  • 177 Answers
SOURCE: Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
Posted on Jun 01, 2010
  • 50 Answers
SOURCE: Our Jazzy Select G.T. power
Hi
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
Posted on May 05, 2011
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
The chair is locked. I had this happen a long time ago and I needed to move the joy stick diferent directions to get it unlocked but I do not remember how. It is a Jazzy 1113.
If it is the older VSI controller, turn on chair. as the battery lights scroll, hold the joystick in the (UP) position until you hear a beep. Then immediately place the joystick in the (down) position until you hear a beep. then place the joystick in center position, once you hear the beep for the final time, it should be unlocked.
If you have a Dynamic controller, turn on chair then press the horn button to unlock.
Sep 15, 2011 | Pride Jazzy 1113 ATS Indoor Power...
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Man has a jazzy 1113 pwc, lights come on, on the controller but chair will not move, the drive motors are engaged
People like yourself are what fuels my strength,please visit:-www.alldatasheet.com its what it says plus its free,you can also download things as PDF Files via an Adobe Reader.have a nice day Colin.
Feb 22, 2011 | Pride Jazzy 1113 Power Chair
I am wondering if anyone knows of a place that will look at my grandfather jazzzy 1113 ats he got it off craigs list and worked fine then all of a sudden the lights started to blink i thought may\be was...
First why can't your granddad get a chair thru Medicare? If he needs it his doctor should prescribe one and then he can get a good chair that will be maintained while he has it at little or no cost. Now until then you can contact Roadrunner Mobility @ 1-800-467-2668 and ask if they have a tech in Granddads area the tech might even be willing to check it at little cost. The flashes indicate a problem and they can tell you the problem if you count the number of flashes between pauses ie 4 flashes pause 4 flashes. I hope this helps you
Feb 21, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Health & Beauty Logo
93 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
