SOURCE: Belt removal or change
i'm not 100 percent possitive but i assume you will have to loosen the tensioner to serpetine belt and it should have a adjustment and just loosen the adjustment. if thats the case you can jump the power steering belt off and back on by prying it with a screw driver and rotating the crankshaft pully
SOURCE: 2003 New Beetle Serpentine Belt Replacement
http://www.mvreader.com/multiview/dayco/catalogSearch.php?autoCatalogSearch=1&make=VOLKSWAGEN&model=BEETLE&year=2003&year_from=&year_to=&engine=All&l=n
This should help. Please Rate My Response! Thanks!
(1) No need to know if engine block coolant drain plug was available. Once the water pump was removed, all engine block coolant was drained. (2) After removing the three engine mounting bracket bolts, I also removed the mount bracket from the the body and made enough room to replace the timing belt easier.
SOURCE: support engine and remove top motor mount for belt
The best way is to rent an engine hoist, you don't want to support the engine with a jack and a block of wood, you could crack what ever the jack is supported on, and if the engine moves, you will never get it lined up with the mount.
SOURCE: how do I replace the belt, remove the pin that
Hello There,
Here's a very helpful video that I shot showing you how to replace the belt, and do maintenance on this particular model vacuum you've listed this repair under.
Please feel free to use the comment field below if you have any questions or would like some further help, I'm always more then happy to answer any of your follow up questions.
Hopefully this was helpful to you. Please be sure to rate the repair helpful if you found this video helpful, or you may also leave feedback for me. This is really appreciated by the Fixya community. Thanks so much!
Chris Jones
GoVacuum.com
Hi jon m clark, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What is the model number so I can look up its setup?
