Question about Cooktops
How do I reset my cooktop that is beeping with error codes EO and 11. This started when water boiled over on the cooktop. I have shut off the power to the cooktop and tried to restart it for two days
This has happened before and when we shut the breaker off for 24 hours it then resets. It won't reset now?
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
SOURCE: error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Posted on Dec 05, 2009
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
SOURCE: kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
Posted on Oct 02, 2010
Does anyone know more about the error codes F5 / F6 on a Whirlpool/Ikea induction hob Type: PLEAC, Model: 80123766 approx. 7 years old?
Call a Wirlpool dealer and give them the code. They will tell you what the problem is. I think F5 or F6 is the control panel. The last time I went to replace one I was better off purchasing a new stove.
Apr 22, 2015 | Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Error codes EO 21
Good Morning sisutl, thank you for your question!
Could the error code possibly be E-21? If so, this error is commonly referred to an issue with the oven thermal sensor. Typically, the over thermal sensor is in the open position. A professional would need to verify continuity of sensor harness and connections. Depending on an accurate diagnosis the part may need replacing. I hope this information help to some degree.
Sep 06, 2013 | Electrolux ICON Designer Series E36IC80ISS...
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 | Cooktops
My cook top is beeping nonstop ! i overboiled some whater and it fell on the cooktop. now it is beeping all the time ! what should i do?
You need to contact your dealer. Tell them to fix it or replace it. Boil over water should not affect an induction stove top.
Jan 09, 2012 | De Dietrich Cooktops
Eo f2 code shows it constantly beeps and was wondering how to fix
Hi
Thanks for using FixYa. Error F2-E0 in your Whirlpool range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 30 in. RC8700 Electric Cooktop
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
