Question about Garden
I have a handheld hitachi leaf blower, bought it recently. It will not start. It worked before, but when I pull the power cord now, it won't pull back, it gets stuck. I disassembled it and everything looks fine. What do I do?
  • 5,324 Answers
When you say power cord is the unit electrical? Or do you mean the unit is gas powered and the recoil starter cord gets stuck?
Posted on Nov 24, 2014
  • 63 Answers
SOURCE: My leaf blower will not start, It keeps flooding
To start: turn the choke off, hold the throttle wide open and crank. You have a carb problem but this should get you going. John
Please rate if this helps-
Posted on Mar 20, 2009
SOURCE: putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Posted on Oct 11, 2008
slohry
  • 87 Answers
SOURCE: Husqvarna 130BT leaf blower - locked-up
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Posted on Apr 13, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
vincob
  • 718 Answers
SOURCE: when we started using toro
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
Posted on Nov 07, 2010
My Hitachi leaf blower was smoking after short term use
The engine gets hot, and the smell is likely not anything to worry about.
Oct 06, 2016 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
Snowblower won t start. pull cord too tight
How long has it setup? Could be varnished up, maybe broken ring, damaged needle bearings. Remove muffler an try to spray some cleaner or fuel in port to free it.
Mar 13, 2014 | Garden
Do you have to use 89 octane on a hitachi leaf blower
Low octane - whatever it is in your area, but must include 2-cycle oil in the mixture.
Nov 18, 2013 | Hitachi 23.9 Cc Handheld Gas Blower
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Husqvarna leaf blower won"t start,changed the plug and gas,now what
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
Nov 06, 2012 | Husqvarna 28CC Handheld BlowerVac
The start cord on the leaf blower won't pull out more than a few inches. Why is this?
pull your spasrk plug out and see if it pulls over then, cylinder might be fullof gas causing hydro lock condition,if so pullit till cylinder dries out then re-install plug and try starting. if all is good check your fuel cap to make sure the vent is working! If it's not venting this causes vacumn that pull fuel out of tank to cylinder after it is shut off...........Good Luck 2StrokeJim
l
May 23, 2011 | Troy bilt 4cycle Backpack Blower 32cc
Need to replace pull cord on homelite z830sb
Start from the bottom and work your way up. This is not an easy repair. You have to almost completely dissassemble the entire blower to replace the cord. You will need a T20 and T25 torx tool, a 9/16' wrench or socket, 40" of #3.5 rope and about an hour. A repair shop will typically charge $20 to $40 in labor for this repair.
Jul 24, 2010 | Homelite Consumer Products MightyLite...
Sep 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
