Toshiba DC-FN20S remote for tv/DVD I need to know how to program it ??? K
    Master:
  • 371 Answers
Hello - Your instructions available here to download:
http://support.toshiba.com/support/modelHome?freeText=DC-FN20S
If you'd prefer, I can paste the remote instructions and send them back to you but would need the numbers indicated in my picture below to do so(from the back of the tv). You will need to have these numbers if you decide to download the guides yourself. Good luck and please let me know if this was "HELPFUL". Thanks!
Posted on Nov 24, 2014
Gigatech
  • 259 Answers
SOURCE: programming my URC-3021
Magnavox 0054, 0706, 0030, 1454, 1254
Symphonic 0180, 0171
Emerson 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
SOURCE: jvc remote control # LP20303-008
http://www.remcomplekt.ru/datasheet/rmt_pdf/codes/LP20878-009A.PDF
Posted on Apr 20, 2009
  • 29 Answers
SOURCE: Program a Toshiba DVD Remote #SE-R0121
This DVD manual tells you how to operate the remote control your talking about...I've got the same one.
http://www.toshiba.ca/web/pdf/SD-3860_E.pdf
What you do is press TV, then hold down the program button while entering the TV code (Magnavox is 10).
Cheers!
Posted on Aug 20, 2009
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Posted on Aug 28, 2009
Dc-lwb1. How do I program it?
Codes are stored in the remote. Using a Toshiba remote, you should be able to press the TV button and control your TV directly.
Jul 05, 2015 | Toshiba Televison & Video
I want to program a universal remote to my Toshiba TV VCR DVD combo TV but I don't know what codes I need
Most universal remotes supply a sheet with the codes you need to program them to your particular make and model. It can take a while to do. If your remote doesn't have the code sheet or your make and model isn't on there, you could try doing a manual search. Not knowing what type of universal remote it is makes it hard to say but usually, there is a manual function that will scroll through every code on the remote until it finds the correct code for your TV.
May 26, 2015 | Toshiba Televison & Video
I have a toshiba md20fmir tv/dvd and a toshiba dc-sb2 remote, can i make them work together and how do i do it, please help
Do you mean the MD20FM1R TV/DVD? The DC-SB2 isn't the correct remote for this TV/DVD. You would need to recode the internal chip. The MD20M1R uses the DC-FL20S remote. A substitute remote is available here: http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=BZ614254 . Alternatively, a universal remote that was programmed at least 6 months after the MD20M1R was released will probably have the correct codes for your TV.
I wish that I had better news for you.
Oct 05, 2013 | Toshiba 24AF42 24" TV
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
I lost the remote control to my Toshiba TV/DVD player: model no. mD13p1. When I put in a DVD, I do not know how to select anything other than "play". I can't watch a movie with subtitles for...
Unfortunately, the buttons on the TV only control basic operations of the DVD player. You'll need a replacement or universal remote that matches the features of the original DC-FN20S remote. Amazon has a Redi-remote that matches the original here: https://www.amazon.com/TOSHIBA-Replacement-Control-MD14FP1-DCFN20S/dp/B009H5Q5NU .
Feb 17, 2018 | Toshiba MD13P1 13 in. TV/DVD Combo
Will a HRMC 8 Program to a dvd/vcr combo by Toshiba?
I HAVE A TOSHIBA TV AND I WANT TO PROGRAM MY REMOTE TO WORK BOTH. THE REMOTE IS A HRMC-B
Dec 15, 2007 | Hughes HRMC11 Remote Control
Toshiba md13p1
You can buy a remote for less than $20 online. Google remote control # DC-FN20S & you'll find it.
Nov 06, 2007 | Toshiba MD13P1 13 in. TV/DVD Combo
Need remote control code
you need to use the dvd codes that are given (20695) and program it under auxilary mode.
Oct 13, 2007 | Toshiba MD24FP1 24 in. TV/DVD Combo
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
