Plugged in my milwakee sawsall and it does nothing. Brushes look fine and getting power through the power cord. What is the next step?
  • 3,506 Answers
Check for power past the switch and at the bushes
Posted on Nov 24, 2014
I have a Kirby G6 and I plugged it in and there is no power to the machine. I checked the power switch in both spots by the boot and the front by the head and still nothing. I tried a new cord and nothing...
Its been awhile since I pulled one of those apart but I had a similar issue with a G and the power switch assembly that sits beside the motor had failed. Its a modular piece that (if memory serves correctly) operates main power and the emptor safety switch. This was the issue with a machine I had in to service.
Oct 05, 2017 | Kirby Vacuums
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
My electric jack hammer 1700W stopped and now nothing happens when i depress the trigger. What can i do ?
Check the brushes first, they're the easiest and most likely cause of your problems. New tools are being equipped with brushes that have non-conductive pins in them that pop out when the brushes wear down so the armature doesn't get damaged. Next, do continuity checks to see if power is geting to and through the switch. Many cords get internal breaks at or near the boot where they go into the tool from frequent bending or at he plug end from being unplugged by pulling on the cord and not he end peice. If the cord is good, check that power is going through the switch.
Oct 08, 2012 | Electric Hammering
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
I replaced the switch the cord and checked the brushes everything looks fine but it won,t work. Help
Interesting. I looked at the following URL to see if there was any safety device that might prevent it from working and I see none:
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1274DVS
If there is nothing happening when you pull the trigger, the only thing you can do is trace the wiring from the power cord through the trigger and to the motor contacts, as shown in the aforementioned URL diagrams. I assume the motor has not seized up on you since you did change the brushes. Not to sound foolish, but did you try changing the outlet you plugged the saw into? In some of the higher end equipment there is an inline fuse that is part of the AC plug assembly. Any chance that is part of the new cord? Blown or missing in-line fuses?
Please keep me informed of your progress as I find this quite interesting. Paul
Sep 18, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Mixer won't start
your problem sounds like the thermister is burnt out.
Sep 26, 2008 | KitchenAid KP2671 Professional 6 Series...
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
22 people viewed this question
k24674
jasbo
jasbo
