Cassette deck spilling when it Plug
Power goes ON and OFF when Plugging
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
I bought an ElectroBrand/Encore Technology cassette converter that is supposed to record tapes into my computer. When I plug the unit into my MacBook, it says the device uses too much power & that port...
Well, you can plug it into a PC and see if that does the same thing. If so it is defective as in shorting components in it. But what do you expect from items that are made in China. You are better off with a restored regular deck and then plugging audio into your computer. You will get much better results that way. All USB decks are junk.
Apr 13, 2014 | Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
To connect your cassette player to your receiver, you may have to use an RCA-type of plug (you know, the red & white plugs on both ends.
BOB (June 23rd '12 3:45am)
Apr 20, 2012 | Yamaha KX 390 Stereo Cassette Deck Single...
I have a TC-WE835S Sony cassette deck I have not use for many years. Today after I insert a cassette into Deck A, it is stuck. I cannot open that side to recuprate my cassette. Please help. Your assistance...
I have the same unit...when it is "ON" ,plug the power cord off and than try to open the cassette door..
the head mechanism keeps the cassette in,power off will release it..
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Dual-Deck Cassette Player/Recorder...
When playing a tape it may stop randomly and the counter displays zero. I have to push play button again and it goes on; but may stop after a while. It does not depend on cassette type or tape length (I...
This would indicate a power supply problem in that the counter being reset. I would check the entire power supply for a any thermal broken solder joints and redo them with the power off. If you need further help I am in the Chicago area and am known as Skywave Tape Deck Repair.
Feb 07, 2011 | Teac V-8030 Dual Cassette Deck
How to connect phono leads
  1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
  2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
  3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
  4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
  5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
Mar 12, 2009 | Audio Players & Recorders
WE475 Sony Dual cassette deck
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 26, 2008 | Sony CASSETTE DECK Single Dual Cassette...
255 people viewed this question
 Grubhead
Grubhead
