Question about Toro Garden
My Toro SS3200 will not start. No sound when key is turned. No sound when the drive arms are pushed into the parking brake position.
I tried to disengage the hydraulics so I could push it. I tucked them in per the diagram, but the wheels do not turn. I cannot push the darn thing.
  • Toro Master
  • 1,169 Answers
If the main fuse is blown then your not going to get the electric brake to release and it will need to be manually released in order to move the mower even with transaxle place in neutral. Instruction are in the owners manual and if you don't have a copy you can download one from the Toro.com website using your mowers 5 digit model number.
Note: the fuses are located behind the control panel. If 30 amp main fuse or the 25 amp charging fuse is blown then the source of short needs to be found.
Posted on Nov 24, 2014
4 Suggested Answers
  • 391 Answers
SOURCE: I HAVE A TORO WHEEL HORSE MODEL 71223, I PUT A NEW DRIVE BELT ON
The belt or linkage is mal-adjusted or the belt is sticky and will not slip when the clutch pedal is depressed
Posted on Jul 19, 2010
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
DIESELMUDDER
  • 2760 Answers
SOURCE: Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Posted on Nov 13, 2013
When i turn the key I hear a ratcheting sound but the engine isn't turning over
clean battery terminals
charge battery
have a load test done on the battery
Apr 16, 2016 | Toro Mowers - Time Cutter SS3200 32""...
My toro 3200 seems like the transmission is locked
check the brake make sure its disengaged
if it wasnt moved in awhile brake can stick
Feb 07, 2015 | Toro Mowers - Time Cutter SS3200 32""...
I have a 2012 Nissan Versa hatchback when I put the key into the ignition it wouldn't turn the ignition is stuck or locked up need fast solution that won't cost an arm & leg
Make sure the gear shift is fully in the parked position. This is known to prevent cars from engaging at start-up. Twist the steering wheel, push the gear fully into park, or neutral if manual, and make sure the emergency brake is engaged. If you find that it was not in the parked position all the way, it should start up. If the problem is that the key won't turn, try getting some graphite and following the manufacturer's directions.
I don't know a great deal about these new cars, but that's the way it was on older models, maybe those sorts of things don't change!
Sep 25, 2014 | Cars & Trucks
I have a 1996 dodge ram 4x4 magnum it wont start in park i have to put it in neutrul then it starts but when i put it in drive it thinks its in neutrul so to go forward it has to go in drive 2 to think its...
-Adjust the shift cable.
-Make sure parking brake is apply, block all wheels.
-Lose the shift cable connector at transmission control arm. Turn the arm to park position and push the shift handle to park, then tight it.
You should be good to go.
mai
Apr 09, 2013 | Cars & Trucks
My zero turn Toro dont want to start, the battery is good and starter
On mine the arms have to be out the blades have to be off and the parking brake has to be on for it to start hope this helps.
Jun 06, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
2005 ford explorer gear shift stuck in park
Check to see if your brake lights are working. If not, you have a blown fuse for the brake lights or a bad brake light switch on the brake pedal arm bracket.
When you turn the key to ON, a solenoid energizess and lock the sihft interlock. When you step on the brake to shift out of park, It de-energizes the relay so you can move the sift lever. You should hear a click noise with they key in ON position and you step on the brake pedal. TRy this witohout starting the engine & listen.
The bypass emergency procedure is in your owner manual under sift interlock in the index.
But, usually you turn the key to OFF (first click) and then step on the brake & shift out of park. Then start car in neutral and drive away.
It works because you did not energize the shift lock solenoid, by not turning key to ON.
report results and please rate, thanks.
Also, check the wire going to the brake switch under the dash. It may have just come off.
Jan 22, 2011 | Ford Explorer Cars & Trucks
3 year old Toro Z4200 time cutter Z, 19 HP Kohler, engine runs great, new battery, new solenoid, with the seat sensor connected or by-passed, STILL WONT start off the key switch. Clicks at the kill relay....
My tractor is doing the exact same thing now. Did you ever get this problem figured out? I figure it to be a grounding problem, a short, or this "kill relay" problem.
Aug 23, 2010 | Sport & Outdoor - Others
1997 Lincoln Towncar. Shifter stuck in park
There is a switch mounted on the arm of the brake pedal (under a plastic cover held on with 3 plastic push-pins). There is an electical connection attached to this switch. In my case one of the wires had broken and was not supplying electricity to the switch. By fixing the broken wire it allowed the shifter to properly move and got the brake lights working again.
Feb 07, 2010 | 1997 Lincoln Town Car
Key stuck in accessory position
sounds like shifter or brake sensor is not working. Try holding brake peddle down while turning key. Also try turning steering wheel a little.
Jul 22, 2009 | 1997 Toyota Celica
Garden Logo
188 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
