I have a binatone dvr505 which will Not Go beyond the binatone screen . I pressed the power button for 20 seconds. The reset button to no avail. Can anyone help me
SOURCE: FP567s Ver.2 ON/OFF
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Posted on Jul 24, 2007
SOURCE: binatone micro dect phone (cordless 8years aprox old)
hiya sirsam you can get Binatone DECT manuals here
http://www.binatoneonline.com/manual.aspx
Posted on Jun 09, 2008
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
anandg27
  • 1272 Answers
SOURCE: how to do a complete reset of netgear wpn824 v2
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
http://my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 08, 2009
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Tip
How to reset different models/version of San Disk players
Hi,<br /><br />Learn how to reset the your various San Disk models;<br /><br />Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:<br /><br />1. Press and hold the Power/Menu button for approximately 20 seconds.<br />2. Release the Power/Menu button.<br />3. Press the Power/Menu button again to turn on the player.<br /><br /><br />Resetting a Sansa View, Fuze, or Clip player:<br /><br />1. Slide and hold the Power switch up for approximately 20 seconds.<br />2. Release the Power switch.<br />3. To turn the player on, slide the Power switch up then release instantly.<br /><br />Resetting a Sansa Express player:<br /><br />NOTE: The device can be either ON of OFF.<br /><br />1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.<br />2. Release the buttons.<br /><br />Good luck.<br /><br />
on Nov 24, 2010 | Audio Players & Recorders
I have forgotten my passcode to get inton my binatone 742 homesurf tablet can i unlock it?
All I want is to unlock pattern for my second hand home surf tablet, I can t do nothing with it so those who say connect it to laptop or PC etc. I need a solution that works and done without having to pay anything.
Jan 25, 2014 | Tablets & eReaders
Coby mid7048 won't boot past Android screen and won't turn off
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
Dec 08, 2013 | Coby Kyros MID7048 7" 4 GB Slate Tablet -...
My garmin will come on but nothing appears on the screen
Try to connect the Garmin using the USB cable to a PC. Does the Garmin go into communication mode? If so - load MyGarmin.com on a PC/Mac and try to update it to the latest available software version (if available). Be sure to connect it to a wall / car charger to avoid the battery running out while updating.
If communication mode doesn't start - power off. Then press the On button for at least 20 seconds for a soft restart. If no response, try a master reset reverting back to factory mode. For this power down - then press the lower right corner of the screen for at least 20 seconds while pushing the On button. Wait for a question to appear to clear all user data.
Jul 05, 2011 | Garmin nuvi 260W GPS Receiver
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
The screen won't go past the opening screen "Binatone Carrera". I've tried the reset button, to no avail. The device is a Binatone Carrera X350. Do you have any thoughts on how to repair...
hi
Firsdt remove sd memory card from it
And press power button for 20 seconds
then it reset.
then try also reset button u can do it .
May 27, 2009 | GPS
Set up problems
Then it sems that you have set up your router with a different user name and passwd..the reset the router and the try to log in to the router and reconfig your router..
To reset the router, the best way is to press and hold the reset button for 30 seconds, or to press the reset button for 60 seconds..and for first 20 sec hold the reset with the power cable connected and for the next 20 sec with out releasing the reset button disconnect the power cable and continue holding the restet button , and after 20 sec reconnect power back and then continue holding the reset for another 20 sec..
and this would fix your problem..
Dec 01, 2007 | D-Link AirPlus DI-524 Wireless Router
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
