Question about Sony Playstation 3 (PS3) Console
I have sound on my TV from the PS3 connection via HDMI, but no display...
I connected my PlayStation to the Toshiba TV I have and I get the sound but no picture. the PlayStation works on other TV's and my computer works through the HDMI on the Toshiba. How can I fix it to get the picture?
    Problem Solver:
  • 15 Answers
From stand by (red LED) press and hold the power button, after about 5 seconds the PS3 will make a second beep. let go of the power button. This will reset your display settings.
if it asks you to display in HDMi and the screen remains black there after, just wait 30 seconds and it will default back to a lower resolution. This usually means that you have an HD READY TV which only supports 720. You can then cjange the display settings to what ever you like in the display settings menu.
Posted on Nov 26, 2014
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
SOURCE: PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Posted on Dec 29, 2008
SOURCE: PS3 HDMI PROBLEM WITH SOUND
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Posted on Jan 20, 2009
treborswindl
  • 212 Answers
SOURCE: sound keeps cutting out momentarily on ps3
Make sure game disk is clean and scratch free. Try and hook up the video with original AV cables (Red,Wht,Ywl) and unplug HDMI.Try another HDMI cable. If none of these help you could have bigger problems. Good Luck.
Posted on Nov 23, 2009
No display
Hi,The settings on the PS3 are sending the video signal throught the HDMI port. Either go through the XMB via system settings, display settings,or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via HDMI as well.
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Have no visual display from hdmi - only sound
The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings, ... Or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
All: Try this -
P
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Ps3 video
Try turning off the system then hold the power bottom until you hear 2 beeps. First beep will be power on. Second beep will be reseting display image.
Aug 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
