Question about Maytag Dryers
<!-- from fixya rte -->Won't blow hot hair - Maytag Dryers
  • 28 Answers
You can use the attached website to get information on your dryer. You will need your make, model, and serial number. You should be able to find a video to help you understand how your dryer heating system works and what parts could be causing the problem. This can be a very technical repair. Do Not Attempt if you are not an avid DIYer or able to understand the directions for the repair. It can be very dangerous if you don't correctly complete this repair.
Posted on Nov 24, 2014
94 Buick Roadmaster AC fan blowing hot and won't shut off
If you have climate control it could be the main processor. Something could be shorting the blower relay to keep it on. You would also need to check and see if the system is still full of freon.
Jul 06, 2013 | Cars & Trucks
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
MY AC blows hot, it wont take a charge. a shop told me it needs a compressor so put on a new one and still won't take a charge and blows hot air
Hello again. is your heater tap actually operating? its not stuck on hot is it? just check the tap actually moves when the hot cold selector is switched.
Jul 06, 2012 | Oldsmobile Cutlass Supreme Cars & Trucks
Removing door knob faceplates
I reckon you are right, they are probably glued on.
You might try a hair dryer and blow hot air on the metal plates, all the whilst trying to pop them loose with a thin blade.
God bless your efforts.
Jul 10, 2017 | Hardware & Accessories
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
I have a Kenmore sise by side refrig on the left (freezer side) it ices up on the bottom
the drain is blocked.slime builds up in the drain line and then the water freezes in the line,unplug the fridge,melt out all the ice at the bottom of the back panel,you'll see a drain hole there,i use a steemer to blow through the drain line,if you don't have a steemer hit the hole with the hair dryer for a while,then pour hot water into the hole,if the water doesn't drain down the hole try using a turkey baster to blow out the line,or you can try to snake something down the drain hole but be careful,it's made of plastic,when you think it's clear pour hot water down the hole again if it doesn't drain keep hitting it with the hair dryer until the water drains down the hole,sometimes it takes like an hour to free it.
May 11, 2011 | Kenmore Refrigerators
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
