Question about Dryers
Wherever the heating element be - Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
No I can help you unless you post more information
Posted on Nov 24, 2014
Vulcan ducted heating
Do a continuity test on the heating elements, and if they're good then do the same on the sequencers or contactors, whichever you have. The sequencers (or if you have contactors turn on the heating elements). All the fan does is blow air. It blows against the heating element to put out hot air. Either your sequencers/contactor or your heating element is defective.Wait,each sequencers is connected to a fuse.Check the sequencer fuse too. Find the sequencer/contactor wherever the wire feeding the heating element is coming from.
Aug 20, 2013 | Heating & Cooling
Our dryer works but it does not heat up.
Here are the most likely problems, starting with the most common to the least common.
The inspection, testing, and repair will require dismantling the machine.
1) The heating element has failed, needs replacement.
2) One of the "overheat thermostats" or "fuse" has tripped, needs replacement.
3) A wire has burned in two inside the back or bottom of the machine, needs repair. ( Near the heating element)
4) A wire has burned in two inside the back of the machine where the electrical cord is attached, needs repair.
5) A circuit breaker has tripped in your fuse box or circuit breaker box, wherever that is in your house/apartment.
Be blessed.
Jul 16, 2013 | Dryers
Amana NED4500VQ2
Probable causes, by most common to least common are:
1) Heating element ( a coil of special wire inside a heating box) has broken, needs replacement.
2) One of the overheat sensors has "tripped" and needs replacement. ( There are from 2 to 6. )
3) A wire has burned in two, needs repaired ( usually near the heating element).
4) A wire has burned or broken where the cord attaches to the back of the machine. Needs repair.
5) A circuit breaker has tripped in your fuse box, wherever that is. (In your hall, garage, basement, or wherever) Needs reset.
Be blessed.
May 05, 2013 | Dryers
Dryer not heating
Most common cause to least common cause, in order:
1) The heating element has failed, and needs replacement.
2) One of the several "overheat thermostat switches" has tripped, (there are from 3 to 7) located inside the back or bottom of the machine.
3) A wire has burned in two (often near the heating element), needs repair. (That is in the back or the bottom of the machine inside.)
4) A connection has burned or broken where the electric cord attaches to the rear of the dryer, and needs repair.
5) A circuit breaker has tripped in your "fuse box" in your basement, or hall or garage, or wherever it is, needs to be reset.
Be blessed.
Mar 27, 2013 | Whirlpool Dryers
Dryer has power but no heat
Most likely problem to least likely, in order:
1) Heating element has broken (expired), needs replacement.
2) An overheat thermostat has "popped". Needs replacement.
(There are from 3 to 6 of them).
3) A wire has burned in two in the back or bottom of the machine (for example, near the heating element). Needs repair.
4) A wire has burned in two at the place where the electric cord attaches to the rear of the machine. Needs repair.
5) One of the circuit breakers has "popped" in the "fuse box" in the hall, garage, or basement of your house or apartment. (Wherever it may be.)
A letter to "fixya" may get you step-by-step repair instructions if you wish to fix it yourself.
Be blessed.
Mar 15, 2013 | Kenmore Dryers
Dryer does not heat
Here are the most common causes, starting with the most likely to the least likely:
1) The heating element has " bit the dust", needs replacement.
2) One of the "overheat thermostat switches" has failed, needs replacement. There are as few as 3, and as many as 6.
3) A wire has burnt in two inside the back or bottom of the machine (often near the heating unit), needs repair.
4) A wire or connection has failed where the electric cord attaches to the rear of the dryer, usually that is under a small cover.
5) A circuit breaker has "popped" in your "fuse box", wherever that is (in your garage, hall, basement, or wherever) and need to be reset.
If you should choose to fix it yourself, an e-mail to "fixya" could cause someone to tell you how, step-by-step.
Be blessed
Mar 04, 2013 | Dryers
Whirlpool awz135 wont heat up
Check the circuit breakers and see if one has tripped.
There are two circuit breakers that run your dryer.
One does the heating element, one does the motor and controls.
Usually they are together side-by side in your "fuse box" wherever that is.
The circuit breakers may look fine , but still be tripped.
If you will switch them off and back on again, see if that fixes it.
It may take a few times, like 3 or 4.
Other than that, newer models have more thermostats and also a fuse.
Is it possible you could find an overheat element you missed, like not with the others?
Be blessed.
Be blessed.
Feb 18, 2013 | Whirlpool Dryers
No heat
In order of " most likely to be the problem" to least likely, here goes.
1) your heating element has failed, usually they burn into two pieces.
2) One of the few or many "overheat sensors" in the back or the bottom of your machine has failed.
3) A wire (for example: to the heating element), has burned in two in the back or the bottom of the machine.
4) The place in the back of the machine where the electric cord hooks to the machine has failed in one spot.
5) A circuit breaker has tripped in the "fuse"box in your hall, basement, garage, or wherever.
Asking the question at "fixya" could get someone to tell you how to fix it yourself, if you wish.
Be Blessed.
Feb 16, 2013 | Dryers
Dryer is not getting hotv
In order of probability, depending on the year and model of the dryuer.
1) Your heating element has "bit the dust" (failed).
2) One of the several "overheat thermostats" that are located in the rear or bottom of the inside of the dryer has failed.
3) One of the wires inside your machine (either near the heating element, or connected to the heating element) has burned in two.
4) You have no current to that "leg" of the dryer, the circuit breakier (in you hall, laundry room, garage, or wherever) is popped.
5) The connector board where your dryer cord hooks to your dryer is "toasted".
Should you decide to fix it yourself, a question to "fixya" could cause you to receive step-by-step instructions.
Be blessed
Feb 11, 2013 | Dryers
Kenmore elite he4 moder 110 won't heat
In terms of likelihood, here is what's wrong:
1) The heating element has failed.
2) One of the several "overheat thermostats" has overheated and failed.
These are found in the back or the bottom of the dryer in the rear.
3) One of the wires to something, like the heating element, has burned in two.
4) The panel where the electric cord attached to the back of the dryer has failed. This will be inside the back of the dryer, usually behind a small plate.
5) The circuit breaker for the "heating" circuit wire of your dryer is popped and needs to be reset. (That is the circuit breaker found in your hall, or basement, or garage, or wherever.)
If you decide to fix it yourself, a question to "fixya" might get you step-by-step instructions.
Be blessed
4)
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
