Question about Ovens
After running the lower oven "self-clean" function, the lower oven does not get hot. Upper oven still works fine.
Removed the lower oven temperature sensor and tested it for continuity/ohms resistance. Originally I thought this was the problem - ordered and just replaced the temp sensor. Installed the new temperature sensor - lower oven still does not work. Re-checked the original temperature sensor - and it measures 1070 ohms - I originally read it as "open" - my mistake on the original diagnosis of the problem. What can I check/test to better diagnose the problem? Thank you, Jim Craig - Healy, Alaska
  • 3,368 Answers
Try the heating element, it could be open. Also check to see if it is getting voltage.
Posted on Nov 26, 2014
Testimonial: "Will check the heating element ASAP - what would be a normal ohm measurement for the heating element? Thank you for the followup to my question - big help. Jim"
  • Jim Craig
    Jim Craig Nov 29, 2014
    Removed and tested lower oven heating element: 17 ohms of resistance. Is this the correct amount of expected resistance in a heating element? Thanks, Jim
4 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: Kenmore gas range model 362.75875691
Yes. I completely agree with you. Both relays would not go bad at the same time.
Posted on Nov 15, 2010
KevinWhite
  • 1902 Answers
SOURCE: After running a self clean
Hello & Welcome to FixYa
You are on right track, as you have already checked the sensor which has around 1100ohms so the problem is with the electronic control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Dec 27, 2010
bradt54
  • 3 Answers
SOURCE: oven temperature way too hot
The ohm's on the temp sensor is adequate if measured at normal room temperature. Next check the wiring from the sensor connector to the control board for continuity. Also verify there isn't any corrosion on the connection to the board. If that is good, visually inspect the control board for burnt areas as that will be the only other component in that function. This control board is NLA but you may find one stashed in someone's old inventory.
Posted on Feb 08, 2014
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
Jun 22, 2012 | Hotpoint Ovens
Kenmore Elite c970-418091 wont work after self clean - Code f30
Here is a how it works post I{ wrote a little while back.:The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. With all that said you can try to cycle the controls by turning the breaker of the oven off for a few minutes the n turn it back on. It should then read PF which is normal. Press the cancel button and try it to see if it works. If not then you will need to replace the control board in the upper panel
Apr 26, 2012 | Kenmore Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
90 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
