Won't go to the channel on menu - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Try a reset to this TV and check if after. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 24, 2014
Tv signal problem
You may have to do a channel search to locate and store active channels in your area.
Jan 09, 2014 | Samsung LA40R81BDX 40 in. LCD TV
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
Main menu screen won't stay up
I have answered this fault earlier , please check this out
Jun 06, 2012 | Krell Showcase Surround 8-Channel...
Why won't my tl2020 model receive any air
Check first in the menu it is set to Air and not CATV or cable./
The signal may not be strong enough for it to pickup on search.
Try to direct enter a known channel that should be there with the remote to see if it gets it or not. If it does you can direct enter and manually add all known channels one at a time in the menu.
May 28, 2012 | Televison & Video
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
Cable won't work after channel 14. Screen just goes to static
You need to make the selection for cable reception in the menu instead of broadcast or air. And when you do then do an auto scan to capture all your cable channels.
May 29, 2011 | Televison & Video
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
