Question about Hunter Carefree Humidifier Model 33201 In Original Box - 1,175 Sq. Ft
When running the machine I have water running all over to fill a bath towel
  • 960 Answers
Check that the drain pan is not overfull and that the filters are clean
Posted on Nov 24, 2014
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
How do I get bath towels to absorb water?
As your towel is not absorbing then you should shop towel which is made of cotton. Because cotton towels are best in absorbing water and are very durable also.cotton towels only as they are most comfortable and soaks all the water from the body properly. If you want you also can buy from there.
Sep 19, 2014 | Home
My Bosch washing machine pumps the water out continuously without ever filling the tub. When I first start a load, the water moves through the detergent dispenser but never gets to the tub. About 5 minutes...
Could be time to call the electrician. If the freeze happened recently you are possibly further inland than me. Lagging on pipes often helps and wrapping external taps and pipes with towels or the likes for winter and with plastic tied over top if in the weather. After super cold frosts we are best not running showers and taps till midday or later occasionally. Vehicles can be similar if it is cold enough. Fill jugs and bottles the night before for breakfast if the water might freeze. If your water might be soon dirty because of a flood or water supply stopped, fill the bath with clean water before it is
Feb 28, 2014 | Washing Machines
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
Water is coming in through the entry hose and running straight out the drain hose. No agitate, no spin, just constant water. Happened after I tried to wash three towels & got an imbalance alarm. R
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Nov 08, 2013 | Haier HLP21E Top Load Washer
Water leaking from the seals of the bath tub... how to fix this problm? already removed the old sealant and put a new sealant, but still the water is coming from the bath seals....
...Why is this listed under videogame consoles? I'm no expert on this subject, but did you double check to make sure you did a thorough job? Heres an idea. Put a bunch of towels near the sealant, fill with water, and wait a little bit. then find the wettest towel; that should help you pinpoint the leak.
Feb 17, 2011 | Video Game Consoles & Games
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Hunter Carefree Humidifier Model 33201 In Original Box - 1,175 Sq. Ft Logo
35 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
