Question about Health & Beauty
I have a quantam 6000z wheelchair,all of a sudden it wont work and reads motor 1 disconnected#192.what can I do im desperate
    Problem Solver:
  • 12 Answers
Sounds as though one of your motor/servo connections has come loose. Here is a manual for the chair. http://www.manualslib.com/manual/134605/Pride-Mobility-6000z-3mp.html#manual
You might wish to check out page 19 of the manual where it describes in fair detail where the connections are and how to reset the breaker.
Posted on Nov 24, 2014
2 Suggested Answers
  • 175 Answers
SOURCE: working on a pride wheelchair that i just put (2)
First, make sure that the motors are both engaged and not in freewheel, and that the charger is unplugged. If it is a constant flash without pause, this is usually an indication that the joystick is "out of neutral", a problem caused by hitting running the joystick handle under a table, for instance, of moisture in the joystick itself. If it is a series of flashes, like 4, pause repeat, then you have a fault somewhere else in the chair. Here's a link to the flash codes for your controller. http://www.dynamiccontrols.com/index.cfm/3,73,237/dna-flash-codes-0307.pdf The flashes, types and manner of flash need to be better described in your posting. Good luck.
Posted on Jan 08, 2010
It started running lower and lower even thought it was fully charged, now the last couple of day I've been getting bus overload and it will not charge
Quantum 6000 - Pride Mobility Products
www.pridemobility.com/pdf/owners.../au_q6000_om.pdf
Pride MobilityQuantum 6000 .... WELCOME to Quantum Rehab, a division of Pride Mobility Products ... The symbols below are used on the power chair to identify warnings, .... Lowpressure may result in loss of control, ... If you must stop, start up again slowly and then accelerate .... Avoid tall grass that can entangle the running gear.
[PDF]Quantum 6000Z - Pride Mobility Products
www.pridemobility.com/pdf/.../intl.../au_q6000z_om.pdf
Pride Mobilitythis power chair and must perform all of the procedures in this manual. The symbols below are used throughout this owner's manual and on the power chair to identify ... NOTE: The Quantum 6000Z and its components are not made with natural ..... Turn the adjusting screw to raise the front of the armrest or to lower the front ...
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
35 posts - ‎30 authors
Feb 05, 2016 | Quantum 6000 Power Chair - Used Electric...
Quantum 6000z Power Wheel Chair's motors are both squeaky. Is there some way to quiet them?
I know it sounds weird, but try snugging down the wheel lugs. Frequently works.
Aug 11, 2014 | Health & Beauty
I have a quantum 6000z powerwheelcair. It's about 3 yrs. old and has never given me problems until recently...while I'm out, the chair just suddenly turns itself off..The last time, I was lucky someone...
Quantums are good chairs, but they have had some electronic issues. My first recommendation would be to see if you have the most current firmware update. This may take a tech with a newer programmer to do.
Quantums usually have a panel on the back of the chair that the joystick and other things plug into. Remove the panel and check the connections. Sometimes, the plugs work loose or begin to wiggle. I've had to secure a few with electrical tape to make sure they don't loosen.
May 20, 2014 | Pride Mobility Products Health & Beauty
Nutron r51
The age of the Nutron is not the issue, unfortunately. I have seen problems with this model right out of the box. The joystick control is the first area to check. If you have to compensate the joystick so far to the right to correct, you may have a damaged joystick gimbal. You may also have a bad joystick control board or damaged connecting cable to the controller on the bottom frame. Check for damaged, pinched loose or disconnected wiring below at the controller module. With a folding frame it is easy for the wiring to be become damaged or dislodged. Check for cut damaged pinched wiring at the joystick. With a handheld programmer (dealer) you can check for error codes in the fault log. With a poor performance issue there may not be a fault recorded in the log of the computer module. I have also seen these motors fail prematurely. In this case your left motor is dragging or weak causing the chair to go left. With a programmer (dealer tool) you can compensate for this while waiting for new parts(temp fix). Sometimes the motor brushes burn or hang up. Try blocking up the chair off the ground and run it no load to check for motor performance and unusual sounds. Check for joystick dead spots or uneven action. A quick check of the joystick would be to plug in a known good one at the dealer to test. With the chair blocked up try tapping the motor housing to see if the performance changes. Inspect the brushes if you have access to the brush caps.Check the obvious first, plugs, pinched, broken wires and partial plug disconnects and corrosion. If you have a voltmeter you can do some checks on the motors and brakes. Going from memory, the motor leads large black and large red should read zero ohms with the 2 small white wires for the brake reading between 60 and 70 ohms. Check the Invacare manufacturer website for exact specs and technical info for this model.
Hope this helps.
Mar 22, 2014 | Invacare Supply Group Nutron R51 LXP...
How do i figure out my problen
thats what it sounds like but the shaking may be one of your motor mounts check your o2 sensors too
Aug 13, 2012 | Jeep Cars & Trucks
Invacare MKIV R11 Flashing lights
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
1 RED BAR:
Low Battery Voltage The battery is flat (more likely).
Or the battery has a bad connection (which is unlikely)
2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
Hope this helps, If so please click the "Yes" button
Regards, Mark.
Jul 12, 2012 | Invacare Pronto M51 Power Wheelchair
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
Jul 12, 2011 | Quickie Wheelchairs Quickie Aspire Power...
My Drive Cirrus Plus power wheelchair doesnt move, it flashes the first two LEDs in red and when moving the joystick it won't move or make the sound. What could be wrong? The battery is at full charge
The Drive Cirrus Plus power wheelchair is a folding frame chair with a VSI controller. The VSI controller (joystick) will indicate a fault code when it detects a problem with your power chair. It is manufactured by a company called Penny Giles Drive Technology. An LED flash code of 2 on the battery display indicates that the left motor is disconnected. There may be a brake fault also.
The left motor can be disconnected at the plug where the VSI harness plugs into the motor plug. The pins for the motor or VSI output may be pushed back in the connector or not making contact due to corrosion or dirt. Unplug this connector and inspect the pins and make sure they are making good contact and are clean. Spray contact cleaner on the contacts to clean or re-orient the pins to make better contact. The folding frame of the chair may have dislodged the connector. The wiring harness from the motor may be pinched or cut. The brake wires and pins may have become disconnected also. The brake lever may be in the disengaged freewheel position causing a fault, so put the brake lever in the correct position. Strictly speaking, this fault code is for the motor only, but always check the motor/ brake assembly since the wiring runs from the same plug.
A certified technician will have a hand held programmer to read the computer (VSI) fault log and determine the number of error codes for the various components.
Using a digital voltmeter you can check the motor at the plug. The two large wires on this 4 pin plug go to the motor; the two small wires go to the brake. On the resistance scale the motor should read between 0 and 1.6 ohms. The brake should read between 30 to 60 ohms.
There is a chance that the output of the VSI controller is bad. To test this swap the left and right motor output connectors from the VSI. If the error code now indicates right motor disconnected (flash code 4) you have a good VSI and bad left motor. Swap the leads back after you are done with this test.
Try blocking up the chair and see if the motor runs with no load on it or after spinning the drive wheel by hand. You can also inspect the motor brushes for burning and wear. If you pull the brushes, do this carefully and blow out the dust from the motor armature. This may allow the motor to work again for a short time.
You will probably need to hire a technician if, after checking for bad connections and the brake lever in the wrong position, you still have problems. I like to replace the brake/ motor/ gearbox as a complete assembly to avoid future problems. Labor for the diagnosis and reading the fault code log with a hand held programmer should be under 1 hour. A return visit to replace the motor brake gearbox is under 1 hour. Hope this helps.
Dec 25, 2010 | Drive Medical Cirrus Plus Folding Power...
I am loosing green lights on my joystick quantam 600 power chair what could be wrong
The green lights will gradually go away as your battery is being used, this is completely normal. You batteries should last for around 5-10 miles of use. If you find that your battery light falls into the red after only 2-3 hours of use and you have been charging the batteries every night for at least 8-10 hours, contact your manufacturer for service.
Oct 11, 2010 | Pride Mobility Products Quantum Jazzy 500...
I have a Raskel and put 2 new batteries on it but the motor won't kick in when you push on the pedal to make it go. ...
hi,im disabled myself,thats why im here,please rate me as in thumbs up 1 to 4.visit:www.alldatasheet.com & download the troubleshooter for your product as PDF File.get if you already havent on your comp,an Adobe Reader for you to read the troubleshooter.hope this was of help,colin.
Aug 22, 2010 | Electric Mobility 3 Wheel Motorized...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
