Question about Janome Sewing Machines
My Janome 9000 has power and will go between screens but when I push foot pedal it always goes back to original screen without sewing. Stuck in a start up loop. Does it need reset?
Shut power off for an hour. Cleaned bobbin area. Retreated unplugged foot control. Tried various sewing options.
  • Janome Master
  • 1,860 Answers
You can try doing a reset or you may need to have the motherboard checked
Posted on Nov 24, 2014
4 Suggested Answers
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
bargainbox
  • 1388 Answers
SOURCE: my janome memory craft 9000 sews without pushing
Inside the foot control is a component called a supressor.......it is there to reduce or stop the "crackle" interference you may have on TV & Radio when using the machine.
It is not necessary for the functioning of the machine, but when it fails, or burns out, there is generally an acrid smell of burned plastic.....then it runs on by itself and you need to turn it off at the switch to stop it.
Best suggestion if you are not comfortable about opening electrical items, is to take it to a Janome service centre and tell them exactly what is wrong, as described above.. "a burned out suppressor, and the machine now runs by itself"
They ought to be able to do this for very little money really, it is a 2 minute job.......if it has been a while since the last service, you may wish to consider having it all done at the same time, depends on usage and budget in the end.
Let us all know how you get on.
www.bargainbox.com.au
Posted on May 01, 2009
SOURCE: My 9000, on regular sewing, is My 9000, on regular sewing, is "jumping" ahead as I sew....kinda like the foot pedal is stuck. Anyone every have this and if so, is it something I can fix or do I need t
it's definitely not suppose to be jumping ahead.
have you checked the foot your using on the machine to make sure it's on correctly?
you might also check the feed dogs to see if there in the up position, in the needle plate.
if nothing I suggests works then I agree to take it to a janome dealer & let them sew on it & see what it does with them
Posted on Mar 30, 2012
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Sep 13, 2017 | Janome Sewing Machines
My Janome memory craft model 9000 sewing machine is now sewing at one slow speed. The quality of the stitch is good but too slow what should I look for?
Your speed slide sensor is bad. Your local repair shop can fix it. There is a chance it's the foot pedal. If it's still slow when you sew without your pedal, then it's the sensor.
Feb 25, 2015 | Janome Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9000 motherboard fault?
I would suggest to get another option, those motherboards are
expensive
Sep 26, 2012 | Janome Memory Craft 9000 Computerized...
Mar 30, 2012 | Janome Memory Craft 9000 Computerized...
My Janome sewing machine wont stop.
The only thing I can think of is that the foot pedal may be slightly stuck and not returning fully up after being depressed. Unplug the foot pedal and check for anything stuck there then give it a good wiggle up and down a few times.
Oct 19, 2011 | Janome Memory Craft 9000 Computerized...
My janome memory craft 9000 sews without pushing the foot control. It's like the foot control is stuck even if I haven't pushed it. I have to shut the machine off to get it to stop.
Mar 23, 2009 | Janome Memory Craft 9000 Computerized...
Says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
Touch screen not responding
Hi, my dealer told me mine might be going and it would cost $500 to repair it and it would have to be sent back to Janome for the repair.
He said when it goes, it will be stuck on the last stitch you used.  You can still probably keep it for a straight stitch machine if you did not want to send it for repair.
Jan 06, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
52 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
