Question about Tassimo T-Discs: Gevalia Dark Italian Roast T-Disc Pods Case of 5 packages; 60 T-Discs Total
How to stop a water leak in the base of my tassimo coffe maker T55
UNABLE TO PREVENT WATER LEAKING FROM BASE OF WATER TANK
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
Base of tassimo leakingat water inlet
call the customer service people - they are good about replacing faulty machines To reach them by phone: 1-877-TDISCS1 (1-877-834-7271) 7 days a Week: Monday - Friday 8AM - 10PM EST, Saturday - Sunday 9AM - 6PM EST
Nov 04, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
Where is the water coming from that is leaking from the base of the unit? It is not coming from the drip tray, and we replaced the water tank. The water pools on the right, underneath the water tank t
Does it only leak when making coffee? There are 2 hoses, one that supplies cool water to heating element in base the other one that supplies the heated water from heating element to top of coffee grounds. Typically over time this 2nd hose degrades at heating element connection and begins to leak
Oct 13, 2014 | DeLonghi Perfecta ESAM5400 Black Espresso...
I've got a miele g640, and the drainwater motor doesn't stop.The moment i press on/off button, the moment the motor starts to drain water even if there isn't any program started.
Your d/w has leak detector built into the base frame out the unit and it has detected the presence of water in the base frame,causing all functions to be overridden except for the drain pump to come on(it is there to prevent water from leaking onto the floor and ruining the flooring in the kitchen) The two leading causes of water in the base frame are;
oversudsing causing water to enter base from vent in the rear of the tub
the seal on the circulate (wash) pump is leaking
Good luck,
Gene
Jul 26, 2011 | Dishwashers
Is it safe to use CLR to clean the Tassimo? The directions say not to use on coffe makers that hold water continuously.
White vinegar is usually recommended for coffee makers.. I would go with that..
"The directions say not to use on coffe makers.........."
Dec 11, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Braun Tassimo Coffee
Return it, I called Tassimo & it's a problem.
Sep 15, 2007 | Braun Tassimo Espresso Machine/Coffee...
Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
Feb 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Tassimo T-Discs: Gevalia Dark Italian Roast T-Disc Pods Case of 5 packages; 60 T-Discs Total Logo
450 people viewed this question
Top Tassimo Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Tassimo Wine and Spirit Expert? Answer questions, earn points and help others
