Question about Ovens
My weltec oven stays on "00.00" and those numbers are blinking, next to it it says "auto"... I cant turn my oven on to cook my pizza. How do I set the time so I can use it again???
  • 3 Answers
SOURCE: cooking
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Posted on Feb 17, 2008
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
Oven cleaned but will not open,has been cleaning for three hours
This is a safety feature of the oven. When the oven cools down you should be able to unlatch and open the oven. I accidentally did this (closed the latch) when cooking a pizza, fortunately I turned to oven off and the pizza did not burn.
I hope this helps.
Feb 09, 2016 | Ovens
When cooking Pizza at 220c the top burns-even though the element is on the top and the pizza in the bottom third of the oven, and the base is uncooked - this also takes 30 minutes to cook?
you are using the broiler to cook it,the upper element is the broiler,the lower one is for the oven,turn on the oven so that the bottom element is on,if it doesnt work,then that is the problem
Jul 19, 2015 | Ovens
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
Cooking
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Kenmore Electric Self Cleaning Stove 790.95660103 Oven On All The Time
There is a relay in the electronic control of your range that is stuck closed causing power to be applied to the element continuously. The relay is an integrated part of the control and isn't replaceable.. The repair would be to replace the electronic control(clock).
Feb 24, 2018 | Kenmore Ovens
Lincoln pizza conveyor oven
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
Dec 03, 2007 | Ovens
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
