Question about Garden
Ford 555A backhoe. Can you tell me what the two lights on right side of dash mean. One looks like an upside down light bulb with a teardrop in it. The other one looks like a round gear. Backhoe runs fine and everything checks OK. but the two lights just came on. HELP PLEASE !!!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 78 Answers
I would have to guess the teardrop one is a glow light if it is a diesel engine. An the round gear is the PTO light
Posted on Nov 24, 2014
johnny5846
  • 379 Answers
SOURCE: when brake pedal pressed side lights come on
hello zeeko1 , over here when that happens its because someone put a single element bulb where a double element bulb goes , now this bulb you take out to fix the problem , look at the bottom of the socket see if it has 1 contact point , then look into the hole where the bulb goes , i bet you see 2 contacts , this single contact bulb is shorting out into the other circuit back feeding voltage to other circuit . cheers mate !
Thanks for using FIX YA !
Posted on Jan 28, 2009
SOURCE: Volvo S80 - Low beam out - Changed bulb & fuses
all i did i unpluged the batter for 5 min and pressed the brake pedual while the batttery was unhooked and when i plugged it back in it solved my problem it has been working all day fine
Posted on Jul 03, 2009
  • 580 Answers
SOURCE: 2004 ford focus headlights
You need to replace the high/low beam switch
Posted on Jul 10, 2009
  • 1986 Answers
SOURCE: what does dash light shaped like upside down
It should be the tire pressure warning light.. check your tires
Posted on Aug 13, 2009
Testimonial: "thank u that was very helpful. I have no owners manual to refer to. we bought the car used from a dealership and later found there was no owners book"
redbeard00
  • 957 Answers
SOURCE: Warning light --Upside down horseshoe with exclamation point
It should be letting you know that you have a tire pressure problem. If you still have the owners manual read it. It will explain what to do, what to look for and how to reset the light if need be.
Posted on Nov 12, 2009
My right front turn signal on my 2001 ford ranger doesnt work and my inside right turn signal light on dash doesnt work and flashes really fast. Buld on right side was replaced and works when lights
was the correct bulb used? this sounds like a single function bulb was used NOT the bulb that will light with the headlights and ALso produce turn singles
Dec 06, 2014 | 2001 Ford Ranger Regular Cab
When the little gear light comes on what does it mean?
WELL, # 1 there is no Gear light on a Taurus, However there are 2 possibility that look like it, # 1 is a Light warning bulb,tells U that there are lights that need attention, # 2 is a traction control bulb,that has 2 Possible Diagnosis's there. 1 is Low Tire Pressure,2 is either a sensor has failed Or the Speed ring is dirty Or has failed also,that Problem Means you Need to have the Brake System serviced
Jul 26, 2014 | 2000 Ford Taurus
Yellow dash light, looks light light bulb with "!" inside of it
Somethign like this...
This symbol it means you have a light bulb out.
This symbol in orange stands for tire pressure monitor (TPMS sensor).
Hope this help (remember rated this).
May 07, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
Upside down light bulb light on in 2001 windstar se
This means you have a marker light out , check tail lights , brake lights , and all exterior light and when your find the bad light and replae it the light on dash will go out.
Dec 01, 2009 | 2001 Ford Windstar
Nov 12, 2009 | 2008 Pontiac Vibe
Light on in dash like upside down bulb next to door open warning light
I believe it means that you have a bulb burnt out somewhere on the exterior of your vehicle
Oct 05, 2009 | 2001 Ford Windstar
2007 vw jetta warning light on instament panel?
OK, It means you have a light bulb out.
Sadly, it doesn't tell you which one though. It maybe a tail, turn, brake, backup, or headlight.
You'll need someone to look around as you run through the lights in the car.
Mar 19, 2009 | 2007 Volkswagen Jetta 2.5 Sedan
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
