Question about Moultrie M80 Game Spy Digital Hunting Trail Camera
Trying to setup and camera will not change through the modes
Moved and cannot find my users manual Trying to record from a video camera to dvd I keep getting message saying to select mode "VR MODE OR VIDEO MODE" and I cannot get it off How do I...
That usually refers to a timing mode. You may have a button on remote to change the recording time length. If no one button. you may have to go through the setup menu on the dvd player. Hope this helps.
May 29, 2011 | Sanyo DRW-1000 DVD Recorder/VCR
How do you set the date on the Vivitar Vivicam X014?
1. Turn on the camera
2. Press the SET button (lower right).
3. Press the "trashcan" button ( to the right of the SET button) to scroll through the setup menu, 15 times, to get to the calendar icon.
4. Press the "ViviLink" button (below the SET button) to scroll down to "date setup."
5. Use the buttons surrounding the SET button (Scene, Trashcan, Flash, and ViviLink) as left,right,, up, and down arrows. Use up and down to change the month, then right to get to the date and up/down to change it, then right again to get to the year and up/down to change it, and so on through hour, minute, second, and AM/PM. Once the clock is set, press MODE to accept the settings.
6. You can scroll up and change whether you want the camera to timestamp the pictures - I turn this off.
7. Press mode again to exit the setup.
Aug 16, 2010 | Vivitar ViviCam 8025 Digital Camera
I have changed the settings somehow on my camera and don't know how to get it back to it's original setting, the quality of my photo's seem quite ***** like and very bright.. anyone know how to change it...
Press the MENU button to bring up the Record mode Menu. You can use this shortcut menu to quickly change image resolution, reset all settings to factor defaults, enter Panorama mode, enable Picture+Sounds, enable Silent mode, change the scene mode (when set to the SCN position on the mode dial) as well as enter the Setup menu.
Hope this helps.
Jan 12, 2010 | Olympus FE-230 Digital Camera
I have a sony cyber-shot dsc-w55 cammera, and my daughter turned the dial that changes the picture modes to many times and now it only records on every picture mode...any ideas how to reset it?
Based on the information you provided, it seems that the Camera is in Burst or Multi-Burst mode.
You may Initialize the Camera as follows:
Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Set the mode Dial on Camera. then, press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
Good Luck!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I-40 camera will not go to picture mode and start taking pictures
Have you done the time/date setup? Online manual says it goes auto after 4 minutes, but perhaps the date/time need to be setup first? Online manual here in case you lost your book :)
http://images.ebsco.com/pob/moultrie/catalog/dgs-i40-user-manual-compressed.pdf
be patient, it takes a bit to load
Aug 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Audio on concepts digital 7.1mp camera
Try accessing the setup menu, options, or menu screens. There may be a mode on the selection dial, or it may be accessible through the video mode.
The camera also may not have audio capabilities.
Apr 14, 2009 | Digital Concepts 54782/54783 Digital...
Sony DSC T77 How to Setup Black and white mode
Hi Allonsoma,
What the manual doesn't tell you is that you need to change the REC mode first to be able to fint the buttons in MENU.
Fist go into the REC mode (the one above menu when taking a photo). Change this to PGM and click OK. Now go into MENU, on the 3/4 page second button down should be a box with a + in the corner. This is the colour mode option. You can now change to vivid, sepia or black and white.
Hope this helps.
Mar 26, 2009 | Sony Cybershot DSC-T77 Digital Camera
Polaroid i737 doesn't have a setup menu
The camera was "Q-Mode", which causes only an abbreviated menu to appear.  By taking the camera out of Q-Mode, which is done on an entirely different menu and not made clear at all in the owner's manual, the Setup menu is available.  The Setup menu is the key to everything in this camera, so my advice is to not keep the camera in Q-Mode.
Dec 25, 2008 | Polaroid i733LP Digital Camera
Lens is not opening in the movie mode,unable to record movie also.
normally there are two possible causes for the problem, 1) the connectors of the rotary switch are dirty or not making proper contact. 2) the cable from the rotary switch is damaged. In both the cases you have to get the swith changed.
Nov 01, 2006 | Nikon Coolpix 3200 Digital Camera
Moultrie M80 Game Spy Digital Hunting Trail Camera Logo
Top Moultrie Home Security Experts
Lawrence Oravetz
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
