Question about Delta Plumbing
Why does my Delta faucet have a major delay when turning it off by touch
  • 3,506 Answers
Delta has a toll free number to call but have your model number ready when you call
Posted on Nov 24, 2014
How do I override the touch feature and convert to a regular faucet
Just buy a new one, don't waste money and tine,
Jan 11, 2016 | Delta Plumbing
Just installed a Delta Touch20 kitchen faucet. When using the touch feature the faucet turns down to a trickle but does not completely shut off, even after several minutes. Any suggestions?
Check installation manual if there is some indication about some kind of advice for this case. If there is no indication for the user, most probably your Delta Touch20 kitchen faucet is defective. Check your warranty terms about how you can return it to be changed or send it for service, so probably you'll have to uninstall it.
Jul 03, 2015 | Delta Plumbing
Touch faucet
Make sure your battery pack is not touching anything else except for some wood it's sitting on, and that it's at least 2" away from the walls. Also possible is that the wiring from the solenoid to the battery pack is contacting something it shouldn't.
Aug 31, 2012 | Delta Plumbing
Re Delta faucet 172-WHWF The spray assembly has a long delay in getting water to it. Would a new diverter valve fix that problem? If so, what is the part number for the diverter valve for this...
Before you start replacing parts look under the sink and make sure the hose leading to the remote spray is not kinked or starting to kink when pulled out.
Mar 07, 2011 | Delta Faucet Delta 172-WHWF Waterfall...
MY SINGLE HANDLE SHOWER FAUCET DRIPS RAPIDLY. THE ONLY BRAND NAME MARKING IS "MASTER PLUMBER". iS THERE A REPAIR KIT FOR THIS FAUCET?
Those faucets are made by different companies and they put their name on them. Delta Price Pfister most likely. Sorry but you will need to pull it apart and see which it is. That is a hardware brand faucet and may be made by any of the major brands.
Feb 08, 2011 | Delta & Single Handle Shower Faucet
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
My Delta type kitchen sink handle is loose and keeps shutting water off. I have to turn it up a lot to keep it going. I could remove Red / Blue plug and do not know what to do beyond to tighten it?
Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
Oct 12, 2010 | Plumbing
Plumbing Logo
178 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
