Question about Delta Pilar Pull-Down Single Handle Widespread Kitchen Faucet with Touch Technology Finish: Stainless Steel, Optional Accessory: With Soap Dispenser
Delta touch faucet having delays
Everything works but when turned off by touch it has major delay
  • 3,506 Answers
Call Delta toll free help line
Posted on Nov 24, 2014
Faucet works sporadically even thought solenoid is disconnected
You are saying that the water comes on by itself? What water pressure do you have?
Apr 08, 2016 | Delta Pilar Pull-Down Single Handle...
I replaced the timing belt on a 2003 Hyundai Accent 1.6 engine. I'm having problems starting the engine. What are the steps to putting it back on time?
If by timing you mean that you aren't sure that you have the belt on the cam/crank assemblies properly, now is a bad time to mention it. This is an interference engine. Proper alignment of the crank/cam with the timing belt is critical and must be exact or serious internal engine damage will result. Even turning the engine too far without the belt properly aligned can damage pistons and valves. At this point if you didn't get it right, the damage is probably already done. For a quick check, disable the fuel pump, pull the spark plugs and perform a compression check. If it doesn't pass, take it all apart and assess the damage and repair as necessary.
Nov 25, 2015 | TBK Timing Belt Kit Hyundai Accent 1 6l...
I have miss fire on cylinder#5 and random misfire I chang plugs wires ign. coil and still misfire 08 dodge grand caravan
have you had the OBD codes read , if not i'd have that done , note the codes , if any , clear them, as claering the codes can sometimes be all that needs doing , if no change post the codes and will be able to locate the sensor/switch causing the issue , another thing to check would be the compression in that cylinder , if low then investigate from there ie valves , head gasket etc
Jul 23, 2015 | Gates 2008 Dodge Grand Caravan Accessory...
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Jan 07, 2015 | DIGITECH RP500 Guitar Multi-Effects Pedal
How to find timing when installing timing belt to mazda protege?
Personally, I use a paint stick to mark the original belt location. Then I take the belt off and transfer the marks to the new belt. Be sure to put a new water pump in and also a new spring on the tensioner.
If you already took the beloff, then there are actually timing marks. I forget where the mark on the crank is, but it should be slightly obvious. The mark on the gear lines up with a mark on the oil pump. The camshaft gears each have 2 marks. On the front you use the one with the 'e' and the 'I' on the back. The notches have to point at eachother parallel to the cylinder head.
Good luck...
Nov 10, 2014 | Gates 1999 Mazda Protege Timing Belt Kit...
How do i change the water pump on a cadillac deville
  1. Remove the coolant overflow bottle.
  2. Remove the battery.
  3. Loosen the pulley bolts.
  4. Loosen or remove the drive belt.
  5. Remove pulley bolts
  6. Remove all studs and bolts from old water pump.
  7. Pull old pump off. Use a screwdriver to start it but be careful not to bend the old pump. Also, tapping the center of the pulley lightly with a hammer may help loosen it. If it is hard to get out, check and make sure all bolts are removed. When you remove the pump, there will not be enough room to remove the pulley drum from the pump. This is important to remember when installing the new water pump.
  8. Scrape area off with a gasket scraper and razor blade to remove old gasket. Make sure its clean! Spray it with brake cleaner and wipe clean afterward.
  9. Spray both sides of the new gasket with high tack. High tack works much better than the goop because it is clean, even, and seals well.
  10. Slip gasket in carefully and be sure it fits properly over bolts and is in correct placement against block. Press down to ensure seal.
  11. Spray the inside of the water pump with high tack evenly.
  12. Install water pump into correct place against block making sure that pulley drum is already hanging from new pump or you will not get it on afterward!
  13. Install bolts and studs and tighten down.
  14. Install pulley screws and tighten as best you can.
  15. Reinstall and tighten drive belt.
  16. Finish tightening pulley bolts.
  17. Reinstall battery and coolant overflow bottle being sure that bottle is empty.
  18. Let sealant dry overnight.
^if you follow the book and have little experience that is the best way
I have 11 years experience working on cars and 4 years were at a cadillac dealer
This will give you more hand room I Take the 2 nuts off the bottom of the front motor mount and back motor mount, on the passenger side then I jack up the motor on the passenger side end of the oil pan with a board between the jack and the oil pan. You can jack it up a couple of inches, it gives you plenty of room. I leave it jacked up until I'm done, even putting the belt on is alot easier. Then lower the motor, and put the nuts back on the mounts
Sep 29, 2014 | Gates 1993 - 1993 Cadillac 60 Special...
Service manual schematics
If you open up the unit, you may be able to fix the jack if it has come loose and maybe got a broken connection in the process. It may just be a "cold solder joint" causing the problem
Sep 04, 2014 | DIGITECH RP500 Guitar Multi-Effects Pedal
Were can i locate the timing marks on 1997 toyota Rav4
You will have to look at the camshaft gear and crank shaft gear there will be mark in side the timing case where the mark have to align up with the mark on the gears
Jun 01, 2014 | Gates 1999 TCKWP199BH Toyota Rav4 Timing...
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
Jan 14, 2013 | Running
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
Jan 13, 2013 | Running
Delta Pilar Pull-Down Single Handle Widespread Kitchen Faucet with Touch Technology Finish: Stainless Steel, Optional Accessory: With Soap Dispenser Logo
202 people viewed this question
Top Delta Running Experts
Are you a Delta Running Expert? Answer questions, earn points and help others
