Why does my soundbar keep changing sources by itself
    Top Expert:
  • Audio Player... Master
  • 14,161 Answers
just google the queston and you can get more information on the problem that you are having.
Posted on Nov 24, 2014
  • 3,506 Answers
Hard to say without knowing what make and model etc you have
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
Soundbar speaker
Does the soundbar require any form of power in?
Have you tried plugging in an alternate sound source.
Jan 29, 2015 | Televison & Video
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
How do I hook up a home theater system to my tv
The following instruction depends entirely on the design of your TV and soundbar. Soundbars are a device that considerably newer than TV technology and thus are not subject to the variety of build standards to most modern TVs; but are usually compatible.
Turn off your TV.
If your TV has an audio out, or variable out, connect 2 RCA jacks to the left and right channels from the TV to the left and right inputs on the soundbar. If the soundbar is "active" thus having it's own amplifier source; turn it on.
Turn on the TV and increase volume. The soundbar very likely has it's own volume control. Adjust volume on it.
Dec 14, 2014 | Televison & Video
How do i get a manuel for it202b soundbar
The manual can be downloaded from this site.
http://content.etilize.com/user-manual/1022923625.pdf
Follow instructions on top of page 7 using the Source button.
Jun 13, 2014 | iLive It202b 32" 2.1-channel Soundbar -...
Original and replacement both have same problem of big increase in volume every 10 minutes or so and we have neighbors to worry about. Remote doesn't work quickly in turning volume down, but we need to...
The source is your issue. The amplifier or TV itself. Try another TV plugged into the amp or some other sound source like a iPod, etc, to test if TV or amp. This is your next step and should show you the proble!m.
Apr 17, 2014 | iLive itb382b 37 hd wireless bluetoothr...
My Vizio VSB210WS Soundbar is not paring with the wireless subwoofer
bluetooth speakers pair and connect to a 'source' not other speakers.
Mar 19, 2014 | Vizio VSB210WS Soundbar
Technika tksb213 problems
Turn up the volume of your AV source to try, seems like the soundbar can't detect the signal which turing itself off
Dec 25, 2013 | Televison & Video
All static from the sound bar. adjustments don't help. tried different cables - that didn't help. System is not usable at this time.
The manual...
http://www.retrevo.com/search?q=Boston+Acoustics+TVee+Model+Two
Page 7
Distorted sound from the Soundbar.
Change the Trim Level switch setting to a higher number.
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The woofer seems to have interference with its wireless signal.
Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
Feb 08, 2011 | Boston Acoustics TVee Model Two TV...
81 people viewed this question
 Grubhead
Grubhead
